Thread: Low Battery
Results 1 to 10 of 18
  1. Low Battery
    Feb 2015
    bedford & england
    Hi All,
    Sorry if this has been posted before, but got this morning to go work and started the car to see that the battery light had come on, i checked the battery indicator and is was low all the way down to the end, do you think i need a new battery or will it charge up when i start to drive the vehicle?
  2. Re: Low Battery
    Oct 2014
    Leeds, West Yorkshire
    It may charge up but it does sound like it's on its way out. Prob best to just replace it.
  3. Re: Low Battery
    Jan 2018
    Sussex
    55 Post(s)
    Quote Originally Posted by bigjazzie View Post
    Hi All,
    Check if alternator charges it properly. If car has electric heater in heater matrix, when below 6 degrees alternator give's 15+ volts, but I don't know if these audis had those already.
    Current cars:
    2007 Passat b6 2.0 tdi BMR DSG
    2013 Golf MK7 1.6 tdi 5 speed
  4. Re: Low Battery
    Sep 2018
    Witney UK
    19 Post(s)
    If the battery is 5 years old or more, there is a good chance it is coming to the end of its life.
    2017 Audi Q5 Quattro S line Navarro Blue 2.0 litre TFSI, HBA, Powered Mirrors, QVIA AR790 (2 Channel Dash Cameras), Front & Rear parking cameras with smart interface.
  5. Re: Low Battery
    Mar 2009
    Montenegro
    13 Post(s)
    I got sometimes message Low Battery and advise to drive and it will be charged during driving. Never problems and car is almost 9 years old with factory fitted battery.
    Sent from my LG-D802 using Tapatalk
    Audi A6 Sedan C6 2.0 TDIe 2011 Condor Grey metallic
  6. Re: Low Battery
    Sep 2018
    Witney UK
    19 Post(s)
    Quote Originally Posted by Novica View Post
    Given its age, it is my opinion that the battery is near the end of its useful life.
  7. Re: Low Battery
    Mar 2009
    Montenegro
    13 Post(s)
    I have got message this morning:
    Started car without problem and drove the car in city only. It is happening last two years from time to time but no problem to start the car. I have read that alternator is not charging the battery all the time only when needed.
  8. Re: Low Battery
    1837 Post(s)
    Yes a full battery that keeps getting rammed with charge does tend to get, well, animated...
  9. Re: Low Battery
    Feb 2015
    bedford & england
    Hi All,
    Thanks for the reply's much appreciated, been driving over wk end and have had no issues with the battery, maybe b'cos of the cold weather it went down, but now is full, but will keep a eye on it
  10. Re: Low Battery
    May 2017
    Canterbury, Kent
    57 Post(s)
    Hi All,
    It's not necessarily a battery coming to the end of its life - it might be that.
    You might find, as I've been experiencing myself, that your car has an electrical glitch that is causing the car an excessively long time to shut-down after you've turned the engine off and locked her.
    Easy way to tell, is to use the car, shut her down, and watch how long it takes for the hazard light switch on the main dash to go off.
    If all is well with the systems, it should go off in just a few minutes. If there's an issue that's causing it a while to shut down, the hazard light will remain illuminated for an hour or two. If it's staying on for a couple of hours, the cars systems are still running, despite the car being "off", and this is draining your battery. A battery change would not cure this.
    Easiest to check it in the early dark evenings, as it's much easier to see if the hazard light on the dash is still on or not!
    0 2 0
  1. Question Battery charger characteristics for battery voltage maintenance
    By Novica in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 23-01-2016, 01:46 PM
  2. Replies: 0
    Last Post: 23-08-2015, 06:34 PM
  3. Shorted battery by accident now car won't start - battery is good...
    By Nookster in forum Golf MK4 - 1999 - 2004
    Last Post: 19-12-2011, 06:32 PM
  4. BATTERY LIGHT ON 2.7TDi Q 2005 - NO BATTERY CHARGE
    By shairaz1 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 20-07-2009, 02:05 AM
  5. Replies: 6
    Last Post: 11-12-2008, 07:16 PM
