Thread: Low Battery
Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
  1. Re: Low Battery
    #11
    Mar 2009
    Montenegro
    13 Post(s)
    I have notice this feature of the hazard light illumination after locking the car and I was wondering why is happening that. I have notice as well that if you try to open trunk door, while is locked, it will illuminate again.
    Sent from my LG-D802 using Tapatalk
    Audi A6 Sedan C6 2.0 TDIe 2011 Condor Grey metallic
  2. Re: Low Battery
    #12
    Nov 2010
    halkirk caithness
    i need to change my battery on my 2.7 a6 c6 avant can i change it without any problems
  3. Re: Low Battery
    #13
    Oct 2007
    11 Post(s)
    Check your battery manager module has the latest software. Itís different to the MMI. Iíve had battery drain for a year and have just had the software updated. Early days, but it seems to have cured my issue.
    55plate Audi A6 Avant. 3.0Tdi S-Line Quattro.
  4. Re: Low Battery
    #14
    May 2017
    Canterbury, Kent
    47 Post(s)
    Quote Originally Posted by prophet View Post
    What specifically is the "battery manager module"?
  5. Re: Low Battery
    #15
    Oct 2007
    11 Post(s)
    Quote Originally Posted by rjsdavis View Post
    Itís the box that is connected to the battery via a thick cable to the negative. It controls the shutdown of the electronics in the car. It should shut items down in stages to stop the battery draining.
  6. Re: Low Battery
    #16
    May 2017
    Canterbury, Kent
    47 Post(s)
    It’s the box that is connected to the battery via a thick cable to the negative. It controls the shutdown of the electronics in the car. It should shut items down in stages to stop the battery draining.
    Thanks Prophet
    How does one update this? I've bought the triple update DVD set from Audi, that I thought updated all of the systems, including the MMI, last year. Is the battery manager module updated in a different way?
  7. Re: Low Battery
    #17
    Oct 2007
    11 Post(s)
    That I canít help you with. Some threads say only Audi can do it. I took my car to an independent VW/Audi guy. He had to pay a licence to Audi to do it, but the whole job was £60.
  8. Re: Low Battery
    #18
    May 2017
    Canterbury, Kent
    47 Post(s)
    Ok - I can't see an indy specialist having anything more than the latest VCDS with which to communicate with the car... Would appreciate if anyone else could chime in with some info on how to update the battery control module?
  1. Question Battery charger characteristics for battery voltage maintenance
    By Novica in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 23-01-2016, 01:46 PM
  2. Replies: 0
    Last Post: 23-08-2015, 06:34 PM
  3. Shorted battery by accident now car won't start - battery is good...
    By Nookster in forum Golf MK4 - 1999 - 2004
    Last Post: 19-12-2011, 06:32 PM
  4. BATTERY LIGHT ON 2.7TDi Q 2005 - NO BATTERY CHARGE
    By shairaz1 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 20-07-2009, 02:05 AM
  5. Replies: 6
    Last Post: 11-12-2008, 07:16 PM
