Thread: 4 motion manual gearbox oil change? AVF engine 2004
  1. 4 motion manual gearbox oil change? AVF engine 2004
    Apr 2012
    Isle of Skye
    Hi
    I have a 2004 1.9TDI (avf) 4MOTION Estate with a manual 6 speed gearbox.
    it has covered 140,000 miles and I was wondering would it be prudent to change the gearbox oil , if so how difficult, what oil is required , what quantity and any specialist tools required?
    Any assistance appreciated,
    cheers
  2. Re: 4 motion manual gearbox oil change? AVF engine 2004
    108 Post(s)
    1816 Post(s)
    It would be a good idea, the 01E box is a contemporary Audi quattro design and very easy to drain, sligly awkward to fill and level set. You need to drain the Torsen section and the main section and then refill through the side inlet. I don't expect your car has the gearbox oil pump and cooler so the level is set to 4-mm below the oil filler hole and you use a bent piece of rod to check this. The spec of oil should be to VAG G052911 specifications which is a 75w/90 to API GL-5 standards.
  3. Re: 4 motion manual gearbox oil change? AVF engine 2004
    Apr 2012
    Isle of Skye
    Thanks Crasher, that doesn’t sound too difficult, I appreciate the reply.
    One quick question roughly how much oil would I need to refill the Torsen and main gearbox?
    Many thanks again
  4. Re: 4 motion manual gearbox oil change? AVF engine 2004
    108 Post(s)
    1816 Post(s)
    The book of words says 2.5 litres which does not sound much but buy 3 litres and you should be fine. Always check the level cold after the car has been given a run, the level is 4mm below the hole according to ELSA.
  5. Re: 4 motion manual gearbox oil change? AVF engine 2004
    Apr 2012
    Isle of Skye
    Thanks Crasher
  6. Re: 4 motion manual gearbox oil change? AVF engine 2004
    May 2012
    Everywhere
    308 Post(s)
    I would thoroughly recommend Fuchs version of G052 911 as it's cheaper and a 75W-80 so better shifting when cold & tiny bit of economy gain.
  7. Re: 4 motion manual gearbox oil change? AVF engine 2004
    Apr 2012
    Isle of Skye
    Thanks for the reply
  1. Question Manual gearbox oil change
    By didkobandita in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 26-01-2018, 10:09 AM
  2. replacement of a 2004 1.9tdi manual gearbox
    By Mick84 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 03-10-2015, 08:26 PM
  3. Manual Gearbox Oil Change
    By Northsea in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 14-09-2011, 09:51 PM
  4. Gearbox Oil Change 5-spd manual
    By ike in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 30-05-2010, 08:23 PM
  5. Question can you change the oil in a manual gearbox?
    By N47HAN in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 10-01-2009, 09:46 AM
