Thread: Loss of power and 16514 error
  1. Loss of power and 16514 error
    May 2007
    Driving up the motorway yesterday, I experienced a sudden dip in engine power for 2-3 seconds before it picked up OK again. Have driven 20+ miles since without any issues. There was no indicator on the dash but stuck my code reader on, and it indicated a 16514 oxygen sensor malfunction. Have reset the code and will keep monitoring - but just wanted to confirm the two are likely to be linked?
    Thanks!
  2. Re: Loss of power and 16514 error
    May 2007
    Just had a little bit of rough running at cold start this evening - so plugged code reader in and got a 16514 error logged again. So looks like that is ONE problem - but was just wondering if it would explain the dip in engine power the other day when engine was pretty warm, and revs reasonably high. Thoughts appreciated.
  3. Re: Loss of power and 16514 error
    May 2007
    Well, it was MOT time so my indy just down the road swapped the sensor and it seems to have been fine since.
  1. Help, broken down .dpf error & power loss
    By skymaster in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 04-08-2014, 09:16 PM
  2. 16514 - Oxygen (Lambda) Sensor B1 S1 fault code
    By smithy602179 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-02-2014, 07:06 PM
  3. Power Loss, anyone help with these error codes
    By Beaversport10 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 22-02-2011, 12:41 PM
  4. Important Power Loss / Turbo loss on VW Passat 1.9TDI
    By mubsy812001 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-06-2010, 03:14 PM
  5. Please Help Drinking Oil - Loss Of Power - Loss Of Revs
    By mrmonk21 in forum Golf MK4 - 1999 - 2004
    Last Post: 18-06-2008, 05:54 PM
