Thread: Faulty clocks? - No rev or speedo, lots of warnings!
  1. Faulty clocks? - No rev or speedo, lots of warnings!
    Sep 2017
    Tyrone
    Hi, I have an 08 jetta 1.9 tdi. The dash clocks display the miles 75k and trip which is zero, but driving about neither go up, the speedo and rev counter dont work and warning lights regarding oil/abs/airbag etc are on. Once i have the sidelight on the radio etc all light up and work fine but not the clocks. Car is also starting and driving fine.
    Scanned with vcds and the following came up, but not sure where too start if any body could point me in the right direction or have similar experiences? Cheers
    Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
    Control Module Part Number: 1K0 920 964 B HW: 1K0 920 964 B
    Component and/or Version: KOMBIINSTRUMENT VDD 1212
    Software Coding: 0019403
    Work Shop Code: WSC 14557 551 00000
    VCID: 2C5762958FDAA42143-8078
    9 Faults Found:
    00381 - Databus Instrument Cluster
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 6
    Reset counter: 111
    Time Indication: 0
    00779 - Outside Air Temp Sensor (G17)
    010 - Open or Short to Plus - Intermittent
    Freeze Frame:
    Fault Status: 00101010
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 111
    Time Indication: 0
    01316 - ABS Control Module
    008 - Implausible Signal
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 2
    Fault Frequency: 56
    Reset counter: 255
    Time Indication: 0
    00771 - Fuel Level Sensor (G)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 3
    Reset counter: 40
    Time Indication: 0
    01314 - Engine Control Module
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 58
    Reset counter: 78
    Time Indication: 0
    01309 - Power Steering Control Module (J500)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 58
    Reset counter: 78
    Time Indication: 0
    00562 - Sensor for Oil Level/Temperature (G266)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 3
    Reset counter: 40
    Time Indication: 0
    01299 - Diagnostic Interface for Data Bus (J533)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 197
    Reset counter: 78
    Mileage: 0 km
    Time Indication: 0
    00457 - Control Module for Network (J519)
    Freeze Frame:
    Fault Priority: 2
    Reset counter: 78
    Mileage: 0 km
    Time Indication: 0
  2. Re: Faulty clocks? - No rev or speedo, lots of warnings!
    1840 Post(s)
    That's more like a CAN BUS issue, post a full car scan.
  3. Re: Faulty clocks? - No rev or speedo, lots of warnings!
    Sep 2017
    Tyrone
    Hi please see below. I done an output test regarding the speedo and revs but both worked fine during the test
    Thursday,18,October,2018,18:16:37:53651
    Chassis Type: 1K (1K0)
    Scan: 01 03 09 15 17 25 42 44 46 52 62
    01-Engine -- Status: OK 0000
    04-Steering Angle -- Status: Not registered 0001
    15-Airbags -- Status: Malfunction 0010
    25-Immobilizer -- Status: Malfunction 1010
    44-Steering Assist -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: Malfunction 0010
    Address 01: Engine Labels: 03G-906-016-BKC.lbl
    Part No SW: 03G 906 021 PM HW: 03G 906 021 AN
    Component: R4 1,9L EDC 000SG 1136
    Revision: --H08--- Serial number: VWX7Z0H43NK8ZW
    Coding: 0000071
    Shop #: WSC 66565 257 00032
    VCID: 79F98BC13008C18988-802C
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
    Part No SW: 1K0 907 379 AD HW: 1K0 907 379 AD
    Component: ESP MK60EC1 H35 0104
    Revision: 00H35001
    Coding: 113B200D092200FD880C04E4901A00413000
    Shop #: WSC 00046 412 00000
    VCID: 74E7BAF5D76ABCE1DB-8020
    7 Faults Found:
    01487 - System Function Test
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 117
    Mileage: 147789 km
    Time Indication: 0
    Freeze Frame:
    Count: 2
    Count: 2
    Count: 12800
    Count: 321
    Count: 51968
    Count: 0
    Count: 0
    Count: 0
    01486 - System Function Test Activated
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 77
    Mileage: 147789 km
    Time Indication: 0
    Freeze Frame:
    Count: 3
    Count: 2
    Count: 12288
    Count: 320
    Count: 43776
    Count: 0
    Count: 0
    Count: 0
    00778 - Steering Angle Sensor (G85)
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 77
    Mileage: 147789 km
    Time Indication: 0
    Freeze Frame:
    Count: 3
    Count: 2
    Count: 12288
    Count: 166
    Count: 43776
    Count: 0
    Count: 0
    Count: 0
    01435 - Brake Pressure Sensor 1 (G201)
    005 - No or Incorrect Basic Setting / Adaptation
    Freeze Frame:
    Fault Status: 01100101
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 77
    Mileage: 147789 km
    Time Indication: 0
    Freeze Frame:
    Count: 3
    Count: 2
    Count: 12288
    Count: 279
    Count: 43776
    Count: 0
    Count: 0
    Count: 0
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 77
    Mileage: 147789 km
    Time Indication: 0
    Freeze Frame:
    Count: 3
    Count: 2
    Count: 12288
    Count: 295
    Count: 43776
    Count: 0
    Count: 0
    Count: 0
    01423 - Lateral Acceleration Sensor (G200)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 77
    Mileage: 147789 km
    Time Indication: 0
    Freeze Frame:
    Count: 3
    Count: 2
    Count: 12288
    Count: 270
    Count: 43776
    Count: 0
    Count: 0
    Count: 0
    01044 - Control Module Incorrectly Coded
    000 - -
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 77
    Mileage: 147789 km
    Time Indication: 0
    Freeze Frame:
    Count: 3
    Count: 2
    Count: 12288
    Count: 8192
    Count: 43776
    Count: 0
    Count: 0
    Count: 0
    Address 09: Cent. Elect. Labels: 3C0-937-049-30-M.lbl
    Part No SW: 3C8 937 049 D HW: 3C8 937 049 D
    Component: Bordnetz-SG H54 2602
    Revision: 00H54000 Serial number: 00000008452012
    Coding: E4810F2700041500470A00000F000000000859035C00010000 0000000000
    VCID: 326B7CEDADFEF2D109-8066
    Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB
    Component: RLS 180608 046 0204
    Coding: 00208933
    Shop #: WSC 00046
    1 Fault Found:
    01504 - Bulb for License-Plate Light (X)
    012 - Electrical Fault in Circuit
    Freeze Frame:
    Fault Status: 01101100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 78
    Mileage: 147789 km
    Time Indication: 0
    Freeze Frame:
    ON
    Voltage: 11.10 V
    ON
    ON
    OFF
    OFF
    OFF
    Address 15: Airbags Labels: 1K0-909-605.lbl
    Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
    Component: 2K AIRBAG VW8 020 2300
    Revision: 05020000 Serial number: 0038PD21RRU7
    Coding: 0012875
    VCID: 3D715FD164A03DA9E4-8068
    Subsystem 1 - Serial number: 633 SME 6
    Subsystem 2 - Serial number: 6342MSME3B645519G
    Subsystem 3 - Serial number: 6351HSME163E0D28E
    Subsystem 4 - Serial number: 6361HSME163E2919D
    1 Fault Found:
    01221 - Crash Sensor Side Airbag; Driver Side (G179)
    010 - Open or Short to Plus - MIL ON
    Part No SW: 1K0 920 964 B HW: 1K0 920 964 B
    Component: KOMBIINSTRUMENT VDD 1212
    Revision: V0002000 Serial number: VWX7Z0H43NK8ZW
    Coding: 0019403
    Shop #: WSC 14557 551 00000
    9 Faults Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 6
    Reset counter: 111
    Time Indication: 0
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 111
    Time Indication: 0
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 63
    Reset counter: 255
    Time Indication: 0
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 3
    Reset counter: 40
    Time Indication: 0
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 66
    Reset counter: 78
    Time Indication: 0
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 65
    Reset counter: 78
    Time Indication: 0
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 3
    Reset counter: 40
    Time Indication: 0
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 225
    Reset counter: 78
    Mileage: 0 km
    Time Indication: 0
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 223
    Reset counter: 78
    Mileage: 0 km
    Time Indication: 0
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Component: IMMO VDD 1212
    Shop #: WSC 00258 000 00000
    2 Faults Found:
    01176 - Key
    008 - Implausible Signal - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 255
    Mileage: 147789 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 17:34:11
    00003 - Control Module
    014 - Defective
    Freeze Frame:
    Fault Status: 01101110
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 142596 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 20:58:13
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
    Part No SW: 1K0 959 701 AC HW: 1K0 959 793 N
    Component: J386 TUER-SG FT 1520
    Revision: 72009005 Serial number: 00000272888518
    Coding: 0000692
    VCID: 6FEDB5997E4C9F3926-803A
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K0 909 144 C
    Component: EPS_ZFLS Kl. 69 2301
    Revision: 00H15000
    Shop #: WSC 00000 000 00000
    VCID: 2A5B648D852EBA11B1-807E
    2 Faults Found:
    005 - No or Incorrect Basic Setting / Adaptation - MIL ON
    Freeze Frame:
    Fault Status: 11100101
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 147789 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 00:02:45
    Freeze Frame:
    Battery Volts: 11.7 V
    DD
    Temperature: 15.0°C
    Count: 3
    Steering Angle: 0.00°
    Count: 1
    SteerAng n.Init
    00750 - Warning Lamp
    013 - Check DTC Memory - Intermittent
    Freeze Frame:
    Fault Status: 00101101
    Fault Priority: 2
    Fault Frequency: 2
    Reset counter: 50
    Time Indication: 0
    Freeze Frame:
    Voltage: 9.13 V
    PD
    Temperature: 14.0°C
    RPM: 186 /min
    Speed: 0.0 km/h
    Speed: 0.0 km/h
    Count: 0
    Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
    Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
    Component: KSG PQ35 G2 020 0204
    Revision: 00020000 Serial number: 00000000000000
    Coding: 81900A0001060C7F2D04840570085FC690FCA0
    VCID: 0305E92942C48B59D2-8056
    Subsystem 1 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Subsystem 2 - Part No: 1K8 951 171
    Component: DWA-Sensor 001 0104
    Subsystem 3 - Part No: 1K8 951 171
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
    Part No SW: 1K0 959 702 AC HW: 1K0 959 792 N
    Component: J387 TUER-SG BT 1520
    Revision: 72009005 Serial number: 00000340688521
    Coding: 0000692
    VCID: 70EFB6E5637280C13F-8024
    2 Faults Found:
    00097 - Front Passengers Central Locking (Safe) Motor (V162)
    Freeze Frame:
    Fault Status: 00101100
    Fault Priority: 3
    Fault Frequency: 12
    Reset counter: 118
    Mileage: 147789 km
    Time Indication: 0
    00929 - Locking Module for Central Locking; Front Passenger Side (F221)
    Freeze Frame:
    Fault Status: 00111000
    Fault Priority: 3
    Fault Frequency: 25
    Reset counter: 118
    Mileage: 147789 km
    Time Indication: 0
    Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
    Part No SW: 1K0 959 703 P HW: 1K0 959 795 G
    Component: J388 TUER-SG HL 1120
    Revision: 11006001 Serial number: 00000002951844
    Coding: 0000144
    Shop #: WSC 00046 000 00000
    End-------------------------(Elapsed Time: 01:48)--------------------------
  1. Second Hand Speedo/Clocks etc
    By Stagecoach in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 19-07-2012, 12:04 PM
  2. Speedo Clocks Change
    By tona955 in forum Touran - Sharan - Caravelle
    Last Post: 10-11-2010, 01:08 AM
  3. Please Help Fox - faulty digital mileometer/speedo
    By pjgraham86 in forum Polo - Derby - Lupo - Fox
    Last Post: 21-07-2010, 04:52 PM
  4. MK4 GTTDI Clocks faulty?
    By jamesbrit1 in forum Golf MK4 - 1999 - 2004
    Last Post: 07-02-2010, 10:07 PM
  5. advice on replacing speedo clocks please
    By Jeff321 in forum Golf MK4 - 1999 - 2004
    Last Post: 28-06-2008, 12:46 AM
