Thread: Help please: electrical steering column noise
Results 1 to 9 of 9
  1. Help please: electrical steering column noise
    Mar 2007
    Hi all.
    My 2013 A6 C7 BiTDI has developed a weird noise coming from the steering column. The noise sounds electrical?
    Steering works fine. The noise seems to happen during slow steering movement.
    Having a good google i cant see solution to this problem. Vcds detects no errors as yet!
    The noise is similar to this video on YouTube.
    Audi A6 steering wheel noise - YouTube
    any advice could be much appreciated 😃
  2. Re: Help please: electrical steering column noise
    Jan 2013
    Wessex. and Southern France
    109 Post(s)
    Slip rings?
  3. Re: Help please: electrical steering column noise
    Mar 2007
    Hi, thanks for your response. you are the second person which has proposed this....the slipring is something i don’t know much about however I will give it some research. Toying with dismantling the steering wheel this wkd and investigate further. Much appreciate your feedback. Interested to hear if anyone else has experienced this problem
  4. Re: Help please: electrical steering column noise
    May 2009
    Ramsey, New Jersey, USA
    69 Post(s)
    Quote Originally Posted by Buckle View Post
    It might be the slip ring, but it sounded a little more squeaky when it happened in my old A6 C6 - more like this:
    Audi A6 weird steering wheel noise - YouTube
    I haven't heard of this in a C7 before though...
    Now: E 53 AMG 4MATIC
    / Q5 2.0TFSi Prestige
  5. Re: Help please: electrical steering column noise
    Mar 2007
    ironically all the buttons on my steering wheel work. I will plug the car tonight to see if any new fault codes have appeared since i did a scan the other day. Hopefully a defective slipring will have a fault code
  6. Re: Help please: electrical steering column noise
    Jan 2013
    109 Post(s)
  7. Re: Help please: electrical steering column noise
    May 2009
    69 Post(s)
    In my case there were no faults - it was just the slip ring that was noisy (but it was functioning perfectly). It got louder in hot weather, if memory serves.
    Cheers!
    MF.
  8. Re: Help please: electrical steering column noise
    Mar 2015
    Twickenham
    I had something similar in hot weather. Adjusted the steering to a lower position and the noise disappeared.
  9. Re: Help please: electrical steering column noise
    Mar 2007
    Hi all.
    The misses drove the car on Sunday. The steering column was adjusted. Annoying the issue has gone away (For now).
    I imagine the assembly needs a bit of grease. Thanks for everyone’s comments.
  1. Question washer fluid leak on steering column - how to remove column shroud etc
    By flat4fanatic in forum Touran - Sharan - Caravelle
    Last Post: 29-03-2014, 11:28 PM
  2. Power Steering Fluid leak near steering column
    By simagain in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 22-08-2013, 05:19 PM
  3. Please Help Steering column noise
    By henry raison in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-08-2010, 09:15 AM
  4. Noise from Steering Column
    By RN Colley in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-04-2008, 10:04 PM
  5. Can the steering column cowling be removed without removing the steering wheel?
    By rich_jc in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-04-2008, 06:48 PM
