Thread: Rattle under passenger (or Drivers) seat: Not your problem today but maybe someday.....
  1. Rattle under passenger (or Drivers) seat: Not your problem today but maybe someday.....
    Dec 2009
    Dublin, Ireland
    25 Post(s)
    Hi all
    I had been hugely irritated by a rattle from somewhere in the back seat area of my Q7 but could not isolate it. Annoyingly it happened on roundabouts and corners, but less so over bumps. When in for the first service I asked the garage to investigate and they felt it was something that had gotten into the heating duct under the passenger seat. The only cure was to remove the seat & duct, several hours work and several hundred euro in labour.
    I had a moment of inspiration and fashioned a 60cm long extension for a vacuum cleaner from duct tape, a ad-blue filler hose (!) discarded flexible electrical conduit and fished around in the ducting. After a few attempts and different designs I finally fished out the offending item: a blanking plug from the 12V power point.
    Interesting that it was at least 30cm down in the ducting, and not easy to retrieve. There is nothing to stop coins, etc getting kicked into the duct.
  2. Re: Rattle under passenger (or Drivers) seat: Not your problem today but maybe someday.....
    Jul 2010
    uk
    183 Post(s)
    Good heads up
    I thins evening picked up some of the kiddies little toys which got close to the heater ducts for the same reason if they could go in - hadn’t thought about how they’d come back out.
    Loving the ingenuity there also
  3. Re: Rattle under passenger (or Drivers) seat: Not your problem today but maybe someday.....
    Nov 2015
    U.K.
    78 Post(s)
    That’s v interesting thanks for posting. I too have a mysterious rattle type of noise, only happens on cornering and is like something sliding on plastic. Probably a kids thing. I removed various things from the plastic area under the 2nd row seats but it is still there. I may look in this duct. Where is the access point please? I’ve got one of those small-camera-on-a-flexible-stick gadgets I could try that...
    Q7 MY16 272PS S-Line Tech/Tour/Trailer packs, orca black, 21 inch 9.5J rims, rotor grey leather, sunroof, BOSE, ambient lighting, reversing cam, drivers memory seat. Gtechniq Crystal Serum Ultra. Sent from my iPad using Tapatalk.
    | Q7 3.0 TDi ABT Power 325bhp MY16 S-Line Tech/Tour/Trailer packs, orca black, 21 inch 9.5J rims, rotor grey leather, sunroof, BOSE, ambient lighting, reversing cam, drivers memory seat. Gtechniq Crystal Serum Ultra ceramic coating |
  4. Re: Rattle under passenger (or Drivers) seat: Not your problem today but maybe someday.....
    Dec 2009
    Dublin, Ireland
    25 Post(s)
    Move the front seats forward: you can see the ventilation ducts under the front seats.
    There are 3 individual ducts, each approx 5cm x 2cm. The center one that allowed best access. As best I could tell the duct bends down quite a bit. I had about 30 to 40cm of bendy vacuum tube in the vent before I found my object.
    When driving the rattle sounds like it's in the back seat, but if you travel in the back you will see it's under the front seat.
  5. Re: Rattle under passenger (or Drivers) seat: Not your problem today but maybe someday.....
    Nov 2015
    U.K.
    78 Post(s)
    Quote Originally Posted by FortyPlus View Post
    Spooky! That’s exactly what my wife and kids said to each other in the car. Definitely need to look in there. Thanks!
  1. Adjustment of Passenger seat via Drivers Seat buttons
    By Q7quattro in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 12-03-2017, 01:25 PM
  2. Vw 2.0 passat - drivers seat airbag problem help !!!
    By Wolverine747 in forum VCDS - Help Requests
    Last Post: 26-05-2014, 10:08 PM
  3. Vw 2.0 passat - drivers seat airbag problem help !!!
    By Wolverine747 in forum Pushchairs, Isofix, Baby seats, etc
    Last Post: 26-05-2014, 12:20 AM
  4. 2.4 2002 cabriolet electric passenger seat problem
    By ahennessy1 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-08-2012, 11:17 PM
  5. Golf MK4 GT 130TDI Heated drivers seat problem
    By GOLF_GTTDI in forum Golf MK4 - 1999 - 2004
    Last Post: 31-10-2010, 09:55 PM
