Thread: A4 B7 3.0 TDI Quattro Tip issue - 013128 - Control Circuit for Controller for Turbocharger 1 (J724) P3348 Electrical Malfunction - Intermittent
  1. A4 B7 3.0 TDI Quattro Tip issue - 013128 - Control Circuit for Controller for Turbocharger 1 (J724) P3348 Electrical Malfunction - Intermittent
    Jan 2014
    Woking, Surrey
    Hi all
    Just a bit of feedback which may help others
    I've been plagued with the dreaded ' limp home mode' and loss of turbo boost on my 2007 A4 Cab for a while now. The issue seems to be fairly common and typically was worse when driving off after the car had had a good run and residual heat was collecting in the engine bay.
    Finally got around to a scan , results below:
    2 Faults Found:
    P3348 - 005 - Electrical Malfunction - Intermittent
    Freeze Frame:
    Fault Status: 00100101
    Fault Priority: 0
    Fault Frequency: 35
    Reset counter: 255
    Mileage: 155669 km
    Time Indication: 0
    Freeze Frame:
    RPM: 1176 /min
    Torque: 15.6 Nm
    Speed: 44.8 km/h
    Temperature: 87.3°C
    Duty Cycle: 31.6 %
    Voltage: 13.98 V
    Duty Cycle: 12.6 %
    001348 - Sensor 1 for Exhaust Temp Bank 1 (G235)
    P0544 - 000 - Circuit Malfunction - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 0
    Fault Frequency: 2
    Reset counter: 255
    Mileage: 156796 km
    Time Indication: 0
    Freeze Frame:
    RPM: 0 /min
    Torque: 0.0 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 12.08 V
    Bin. Bits: 00000000
    Torque: 124.8 Nm
    Readiness: 0 1 0 0 0
    After much research and testing using VAGCOM I was about to conclude the boost actuator controller was toast - it wasn't moving at all during the various tests and the linkage seemed not to be stiff when pushed with a screwdriver (didn't feel like the actual turbo was causing the issue).
    However, when playing with the 4-pin electrical connector it became clear the small plastic lug had failed and the connector wasn't making a secure connection with the actuator. It wouldn't stay fully engaged.
    So, using cable ties (see picture attached) I effected a temporary repair, cleared the codes and Bingo! Job done.
    I think I may get a new connector - lots seeming available online for a few quid - part number 1J0973704 for reference.
    Hope that helps someone else not go down a more expensive route if they have the same issue.
  2. Re: A4 B7 3.0 TDI Quattro Tip issue - 013128 - Control Circuit for Controller for Turbocharger 1 (J724) P3348 Electrical Malfunction - Intermittent
    Jan 2014
    Woking, Surrey
    Edit - problem reoccured .... same fault code..... so I ordered a new connector (£4.20) and set of connector pin removal tools (£7.00) and renewed the connection. Inside of the old connector was brittle and snapped when renewing... possible cause of the fault but time will tell. Will post back here with an update.
  3. Re: A4 B7 3.0 TDI Quattro Tip issue - 013128 - Control Circuit for Controller for Turbocharger 1 (J724) P3348 Electrical Malfunction - Intermittent
    Jan 2014
    Woking, Surrey
    OK update.... rescanned and the code is almost identical,
    origianl fault above = 013128 - Control Circuit for Controller for Turbocharger 1 (J724) P3348 - 005 - Electrical Malfunction - Intermittent
    latest scan = 013128 - Control Circuit for Controller for Turbocharger 1 (J724) P3348 - 004 - Electrical Malfunction - Intermittent
    it now only seems to lose boost when the car is restarted after being sat 'hot' for a while.... kind of what it was doing before.
    Anyone got any suggestions, or experienced the same?
    I guess it points to the actuator being faulty when heatsoaked, but why would the codes above be slightly different? how is 004 different to 005?
    thanks
  4. Re: A4 B7 3.0 TDI Quattro Tip issue - 013128 - Control Circuit for Controller for Turbocharger 1 (J724) P3348 Electrical Malfunction - Intermittent
    Jan 2018
    Sussex
    55 Post(s)
    Quote Originally Posted by JLBmatic View Post
    thanks
    No difference between 004 and 005 just reappeared.
    I somehow suspect wiring.
    Current cars:
    2007 Passat b6 2.0 tdi BMR DSG
    2013 Golf MK7 1.6 tdi 5 speed
  5. Re: A4 B7 3.0 TDI Quattro Tip issue - 013128 - Control Circuit for Controller for Turbocharger 1 (J724) P3348 Electrical Malfunction - Intermittent
    Jan 2014
    Woking, Surrey
    Thanks. Out of interest what makes you think wiring as opposed to the actuator? Is there a different fault code to distinguish between the two ?
    Also, does anyone know a good supplier of the actuator - I assume they need access to calibration tool VAS 6395A too?
    It drives fine from cold start for a whole journey, but it's the restarts when it's been sat hot for a while which seems to throw it into no-boost . No idea how much to replace the actuator or who could provide that service or supply in UK.
  6. Re: A4 B7 3.0 TDI Quattro Tip issue - 013128 - Control Circuit for Controller for Turbocharger 1 (J724) P3348 Electrical Malfunction - Intermittent
    Oct 2017
    Kegums, Latvia
    Yes, to code the new actuator special tool is needed, it plugs into the new actuator and calibrates it.
    The actuator cost me 250€ + 50€ for the work, note, that is here in Latvia.
    Also I suggest You get the actuator from dealer as they seem to get thoroughly checked ones (higher quality standards for the actuators heading to dealer?) as we went through 2 brand new sealed boxes and all actuators which came straight from supplier whom all failed in fit. We got one from dealer with exactly the same part number and actually older build date and it worked straight away. We noticed that the bad ones actuator leg moved twice as far as the working actuator's.
    Sent from my Pixel 2 XL using Tapatalk
  7. Re: A4 B7 3.0 TDI Quattro Tip issue - 013128 - Control Circuit for Controller for Turbocharger 1 (J724) P3348 Electrical Malfunction - Intermittent
    Jan 2014
    Woking, Surrey
    Quick update..... decided that a complete refurb Turbo + Actuator assembly was not much more money than the actuator alone, no need to calibrate it then plus i get a new turbo not a 100,000 mile one which may have excess buildup on the VNT mechanism....
    Installed, went to test drive and...... no boost until like 2200rpm when it builds quickly and then pulls like a train...
    Limp mode entered with different fault code with flashing coil light.
    000565 - Boost Pressure P0235 - 001 - Regulation range not reached - MIL ON
    Have checked all hoses / vacuum lines & removed and checked the boost pressure sensor under the left hand headlight.... looked ok
    Any suggestions or anyone experienced this before?
    P0235 - 001 - Regulation Range not Reached - MIL ON
    Freeze Frame:
    Fault Status: 11110001
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 160377 km
    Time Indication: 0
    Freeze Frame:
    RPM: 2205 /min
    Torque: 163.8 Nm
    Speed: 20.2 km/h
    Absolute Pres.: 1856.4 mbar
    Absolute Pres.: 1183.2 mbar
    (no units): 108.1
    Temperature: 14.4°C
    Readiness: 0 0 0 0 0
  1. Question Fault code P2563 Turbocharger Boost Control Position Sensor Circuit: Implausible Signal
    By Audikiller in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 28-09-2018, 09:48 AM
  2. Question Fault code P2563 Turbocharger Boost Control Position Sensor Circuit: Implausible Signal
    By Audikiller in forum New Member Introductions
    Last Post: 29-08-2018, 12:21 PM
  3. 005445 - Throttle Valve Controller P1545 - 002 - Malfunction - Intermittent
    By 2fquick in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 13-03-2016, 12:23 PM
  4. Please Help Turbo controller (J724) wanted
    By wjam in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 11-06-2012, 08:03 AM
  5. Please Help Fault code P1571 Main electrical circuit relay elec malfunction.
    By barberysauto in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 28-05-2010, 07:04 PM
