Thread: Could a CV replacement cause bearing failure??
Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 32
  1. Re: Could a CV replacement cause bearing failure??
    #21
    1840 Post(s)
    The trouble with heating is you have to get the unit off of the car, to do that you have to get the upper bolts out and that’s where the problem lies. The bearings are pre packed and rubber sealed, they would not like that amount of heat.
  2. Re: Could a CV replacement cause bearing failure??
    #22
    Mar 2016
    Minervois, France
    53 Post(s)
    I've never tried to press out a bearing without removing the carrier from the car. I don't have a hydraulic puller, which would be difficult to use in the available space, and I wouldn't try beating it out.
    I have never heated a bearing above its operating temperature. The seals these days are heat resistant. Years ago I used a large multi-core induction heater and an expensive contact thermometer, but now, for the little bearings on cars, I use a soldering iron and a cheap non-contact thermometer from Ebay, which is quite accurate enough for the job.
    SKF Induction heaters
    Did this forum help you? Help make sure it's here next time! Follow the instructions at the top of the page to make a suitable donation using PayPal .
    1996 A4 B5 (S2) Avant 1.8T (petrol) 150 bhp code AEB automatic with 79,125 kms = 49,450 miles on 30/07/23
    VW T25 Camper, Alfa 33 1.4 ie, 2 Alfa 33's for parts.
  3. Re: Could a CV replacement cause bearing failure??
    #23
    1840 Post(s)
    The thing is, these bearings are bolted in, with the bolts out it should just pop out.
  4. Re: Could a CV replacement cause bearing failure??
    #24
    Mar 2016
    Minervois, France
    53 Post(s)
    Right. An improvement on the system on my car, then, where the bearing is held in the upright by friction and faith.
    Vorsprung durch technik - eventually
    But not a good idea for use in countries where they slather the roads with salt in the winter.
    The weight saving is negligible, but the production cost saving probably significant.
  5. Re: Could a CV replacement cause bearing failure??
    #25
    1840 Post(s)
    There is a Technical Product Information notice about the bearing moving and the cure is basically Loctite bearing fit! Why didn’t they seal them in from new, in fact still don’t!
  6. Re: Could a CV replacement cause bearing failure??
    #26
    Mar 2016
    Minervois, France
    53 Post(s)
    They shouldn't work loose unless the bearing deteriorates badly and vibrates, or seizes and turns in the housing.
    I have only used Loctite bearing seal as a temporary repair, with owner's consent, or on my own stuff, preferably together with brinelling or pecking the inside of the housing with a center punch to tighten the fit.
  7. Re: Could a CV replacement cause bearing failure??
    #27
    1840 Post(s)
    These do work loose and snap their bolts as the other chap has noticed, if the unit comes loose you start to get cracking noises during slow manoeuvring and there is a special VAG sealant which seals the bearing unit solid, the trouble is then they won’t come out when needed.
  8. Re: Could a CV replacement cause bearing failure??
    #28
    Mar 2016
    Minervois, France
    53 Post(s)
    Sounds like bad design. Have you seen any bearings come adrift on my car's type of arrangement (B5), with a steel hub carrier/upright?
  9. Re: Could a CV replacement cause bearing failure??
    #29
    1840 Post(s)
    Never on any VAG car with the pressed in design.
  10. Re: Could a CV replacement cause bearing failure??
    #30
    Mar 2016
    Minervois, France
    53 Post(s)
    Maybe the design was changed due to the continuous efforts to improve.
    Granted with the bolted cover, the bearing is easier to remove - it practically falls out
  1. rear wheel bearing failure is it common on low miles b8 s line model ?
    By dazbo1972 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 19-10-2014, 03:21 PM
  2. Front Bearing failure for the 3rd time in 6 months!
    By garvey2003 in forum Golf MK4 - 1999 - 2004
    Last Post: 15-08-2013, 03:36 PM
  3. Top strut replacement bearing
    By dos in forum 80 - 90
    Last Post: 05-07-2011, 07:13 PM
  4. wheel bearing replacement.
    By audisingh in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-01-2010, 08:47 AM
  5. Aircon pump (compressor) bearing failure?
    By ac606 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-02-2009, 09:23 PM
