Thread: ABS light,traction cont., handbrake flashing and beeping!
Results 1 to 9 of 9
  1. ABS light,traction cont., handbrake flashing and beeping!
    Oct 2018
    Kent
    Battery was completely drained and now it is coming up with the above as soon as the car is turned on?
    Any ideas?
    Video
    https://www.youtube.com/watch?v=tTIfqqv2Htc
  2. Re: ABS light,traction cont., handbrake flashing and beeping!
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    have you had it jump started, in which case it still has low battery voltage. check voltage with engine running, should be around 14.5V
  3. Re: ABS light,traction cont., handbrake flashing and beeping!
    Oct 2018
    Kent
    Yeah it was just jump started after being collected from the garage so hasn't been driven much to charge back up. I'll get the multimeter on it.
    Do you think once voltage has risen the lights will go out?
  4. Re: ABS light,traction cont., handbrake flashing and beeping!
    Nov 2010
    104 Post(s)
    Hopefully it is a low voltage issue, if they do not clear you'll need a diagnostic scan. The car will need to be driven a while and steering turned lock to lock to clear the ABS ESP lights as well.
  5. Re: ABS light,traction cont., handbrake flashing and beeping!
    Oct 2018
    Kent
    Gave it a drive for a bit and it's not going off. So strange that it's come on just after the battery going.
  6. Re: ABS light,traction cont., handbrake flashing and beeping!
    Mar 2017
    Nottingham
    9 Post(s)
    Start the car full lock the wheel one way then the other then drive give that a try. If no luck you will have to clear them with vcds
  7. Re: ABS light,traction cont., handbrake flashing and beeping!
    Nov 2010
    104 Post(s)
    ok So what's the battery voltage while running and engine off ?
  8. Re: ABS light,traction cont., handbrake flashing and beeping!
    Oct 2018
    Kent
    It's around 11.9 off and about 13.9 running.
    Not charged up enough is it. Gonna have to run it some more.
  9. Re: ABS light,traction cont., handbrake flashing and beeping!
    Oct 2018
    Kent
    Fully charged the battery and it is still on.
    Also inspected the ABS fuses and they look fine.
    No fault codes when scanned.
    Driving me mad!
  1. Please Help 57 Fox ABS Light, Handbrake light, beeping and steering locks while driving
    By netutgamer in forum Polo - Derby - Lupo - Fox
    Last Post: 13-11-2014, 02:07 PM
  2. Please Help oil light flashing and beeping
    By daleosborne in forum Polo - Derby - Lupo - Fox
    Last Post: 09-11-2010, 07:40 PM
  3. 98 1.8 20v sharan oil light flashing/ beeping
    By neilpalace in forum Touran - Sharan - Caravelle
    Last Post: 19-04-2010, 07:39 PM
  4. Caddy Hadbrake light flashing and Beeping
    By fairky in forum The Commercial Range
    Last Post: 26-05-2009, 02:08 PM
  5. handbrake light flashing and beeping
    By johnnyboy in forum Passat - Archive Topics
    Last Post: 26-10-2007, 08:13 AM
