Thread: Mk5 Boot doesn't open - have tried the usual issues
  1. Mk5 Boot doesn't open - have tried the usual issues
    Aug 2018
    London
    Hi everyone, pretty much as it says in the title, I've got a mk5 GTI 5 door and the boot no longer seems to open, to the point where I have to crawl in the back and manually release the latch.
    I've searched the forum (and other sites too), have done pretty much everything in this thread Golf mk5 boot release fuse? and have tried the usual suspects:
    • powered the boot latch with 12V directly - works
    • powered the boot latch from the CCM by providing 12V directly - also works
    • replaced the boot latch with a new one - still doesn't work
    • Also shorted the VW badge handle switch - still doesn't work
    I'm led to believe this is a coding issue or a faulty CCM, it doesn't seem as though the wiring is damaged based on the above.
    Not quite sure how to test this now, a friend with VCDS has helped activate some of the functions in "Long coding" but this hasn't made a difference.
    Does anyone have any idea on what the coding should look like, or is my only option the replace the CCM?
    I'd be extremely grateful if anyone could offer any help.
  2. Re: Mk5 Boot doesn't open - have tried the usual issues
    May 2007
    10 Post(s)
    Were you messing with the coding before the fault appeared? If not, it's not very likely to be a coding issue.
    It would more likely be a broken wire. Have you checked the wiring between the car body and the tailgate?
    You've tested the motor wiring by powering the motor from the CCM connector. But you don't mention anything about the wiring between the handle and the CCM.
    If the CCM isn't receiving the request to open the tailgate from the handle switch, it wont send power to the release motor in the latch.
    You should be able to check that the CCM is receiving the signal from the handle switch by reading the measured values with VCDS.
  1. Please Help passenger door/boot doesn‘t open - Mansfield Area
    By sssaku in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 26-04-2016, 07:07 PM
  2. Question Plastic key doesn't open car?
    By Tripletrouble in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 29-11-2015, 10:21 AM
  3. Please Help Air con problem, not the usual issues...
    By rosskie in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 07-03-2013, 08:08 PM
  4. Tailgate doesn't open on my A4 Avant
    By mr singh in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-07-2010, 08:00 AM
  5. Spare key doesn't open door!
    By Sqwim in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 26-01-2009, 11:59 PM
