Thread: Judder under load.
Results 1 to 10 of 11
  1. Judder under load.
    Oct 2018
    Hartlepool
    I’ve got an issue with a recently purchased 2013 A6 Avant 2.0tdi 177 s line. When accelerating from low revs, half to full throttle, the whole car judders quite badly until around 3,000 revs and is then smooth. At first I thought DMF/Clutch but there’s no noise, I read about similar issues on C6 models and some VW’s including inner CV joints and injector looms? Any ideas? Is this a known issue?
  2. Re: Judder under load.
    Nov 2010
    Shetland & S.Tyneside
    102 Post(s)
    does the judder stop if you ease off the throttle or take your foot off completely (ie. overrun)
  3. Re: Judder under load.
    Oct 2018
    Hartlepool
    I believe so.
  4. Re: Judder under load.
    Oct 2018
    Hartlepool
    Itís got 110k on the clock. Could a clogged egr be an issue?
  5. Re: Judder under load.
    Jan 2018
    Sussex
    52 Post(s)
    Code read with VCDS. If no codes then could be drive shaft joints, but kinda low miles for that.
    Current cars:
    2007 Passat b6 2.0 tdi BMR DSG
    2013 Golf MK7 1.6 tdi 5 speed
  6. Re: Judder under load.
    Nov 2010
    102 Post(s)
    could well be flywheel at that mileage, do you notice any rattle if you change down a gear quickly, say 4 to 3 in overrun and let the gearbox drive engine revs up? that was how I first noticed early signs of flywheel going on a car I had, but a scan would be worthwhile as well. Since from your first description the judder seems to be engine speed related rather than road speed related I wouldn't think it was driveshafts.
  7. Re: Judder under load.
    Jan 2018
    Sussex
    52 Post(s)
    Quote Originally Posted by Rob69 View Post
    Because it judders under load, flywheel seems to not be at fault.
    Had similar issue on Passat, when drivers side inner joint was worn and car had judder under load at low and middle RPM.
    Also was more noticeable when wheel was slightly turned right or left not completely straight.
    Current cars:
  8. Re: Judder under load.
    Feb 2016
    Blaydon, North east England
    37 Post(s)
    What gearbox is in your car?
    You don't say if it manual, STronic or Multitronic.
    2015 A6 Allroad 218 - NEW
    2012 A6 Avant SE 3.0TDi Multitronic - OLD
  9. Re: Judder under load.
    Oct 2018
    Hartlepool
    6 speed manual.
  10. Re: Judder under load.
    Jul 2016
    Chestfield kent
    43 Post(s)
    Hi did you purchase trade or private? If trade I would take it back and get them to locate and resolve the problem, good luck
    2015 FL S-line 2L ultra & 2003 225 TT Coupe
  1. Vibration / judder on acceleration - esp in high gears when engine under load
    By JamesRT in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 09-03-2017, 09:04 AM
  2. Replies: 3
    Last Post: 21-01-2014, 08:59 AM
  3. Banging , Judder Under Load
    By blower in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 12-02-2011, 01:24 PM
  4. Please Help gti tdi 150bhp idle judder and low throttle judder
    By rs250gpracer in forum Golf MK4 - 1999 - 2004
    Last Post: 16-02-2010, 10:42 AM
  5. Passat TDi 170 - extra load v. standard load tyres
    By john@johnsthrel in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 25-08-2009, 06:53 PM
