Thread: Haldex filter part number please
Results 1 to 10 of 11
  1. Haldex filter part number please
    May 2009
    Saddleworth, Yorkshire
    Hi
    I want to change the oil in my cars haldex coupling, I know the oil is G052176A1, but I also want a filter, does any one know the part number.
    I have looked and can only find the number for a MK1 TT - 02D52555
    My car is an 09 2.0 tdi
    Thanks Ian
  2. Re: Haldex filter part number please
    1841 Post(s)
    Only certain axle codes used a filter and typical only on the 3.2 V6. If it did have a filter the number for the kit is 02D 598 574. If you message me your reg number I can tell you if yours has a filter or not. There is no such oil as G 052 176 A1, there is the G 052 145 A1 but that is the gear oil for the diff, not the Haldex, don't drain the wrong one, it has been known! The Haldex oil is G 055 175 A2 which comes as 1 litre, cars without filters need 650Ml and cars with need 720Ml.
  3. Re: Haldex filter part number please
    May 2009
    Wow, thank you so much for your technical reply
    My cars reg is :- WR09 KCE
    Regards Ian
  4. Re: Haldex filter part number please
    1841 Post(s)
    Hmmmm, Fiat Doblo cargo.....
  5. Re: Haldex filter part number please
    May 2009
    Whoops, WR 59 KCE
    Ian
  6. Re: Haldex filter part number please
    1841 Post(s)
    A 0BR coupling so no filter as used on the 0AV.
  7. Re: Haldex filter part number please
    May 2009
    Thank you so much for your advice, I have ordered a litre from Audi
    Just one more question if I may, in your first reply you stated 'don't drain the wrong one' How will I know which is the correct drain and fill plugs ? I am not as stupid as I appear, just don't want to get it wrong
    Ian
  8. Re: Haldex filter part number please
    1841 Post(s)
    The bolt to drain the Halex oil looks nothing like a drain bolt and more like a case bolt, without a picture (can’t do this at home) you may miss the bolt and take out the diff drain bolt, many (including VAG dealer mechanics as documented on this forum) have made this mistake and destroyed thousands of £’s worth of final drive.
  9. Re: Haldex filter part number please
    May 2009
    Yikes, now I am worried !
    I found this clip on youtube, It is well explained and looks straight forward (famous last words), is this correct procedure for changing the oil ?
    I have also read that although the filter is a non serviceable part, it's recommended to remove the pump to clean the plastic filter gauze, would you recommend this ? my car has done 109,000 miles and according to the service history the haldex has not had the oils changed for quite a while
    Servicing Haldex (AWD) System on Golf R - DIY - YouTube
    Thanks Ian
  1. Fuel filter part number
    By qalaray in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-12-2013, 11:53 PM
  2. haldex oil&filter
    By lee58uk in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 24-03-2012, 07:57 PM
  3. part number of the air conditioning filter
    By CloseMix in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 12-08-2011, 09:08 AM
  4. Question 2.0 TDI oil filter part number
    By freebird69 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 25-07-2009, 10:02 AM
  5. haldex filter
    By passat 130 tdi in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-03-2008, 12:19 AM
