Thread: Suspension system inoperative
  1. Suspension system inoperative
    Apr 2018
    sittingbourne
    I have had my 2002 2.5 TDI quattro for 12 months and took it for the MOT, found a few problems and am interested to know if people believe it is worth the time and money to fix it up.
    After reading through many of the posts on this forum i believe i have a leaking bag however when i went to raise the suspension this morning it would not lift at all so maybe now the compressor needs to be repaired/replaced. I also need need a new offside rear inner brake pad and 2 headlamps.
    I do love this car and would hate to see it go to the scrap man but with no mechanics experience and limited funds i am questioning if i should cut my losses now.
  2. Re: Suspension system inoperative
    Aug 2017
    West Midlands UK
    11 Post(s)
    Headlights are going to cost £75-100 each pattern, easy enough to fit but have an awkward bolt that needs a long extension bar on each side.
    Rear pads, £20-30 - easy enough to fit, hopefully the discs are okay!
    Airbags £50 - 70 pattern depending on which type it is.
    Compressor - £???
    With limited experience you could repair it quite easily if you read some tutorials and purchased some tools, it all depends on what your time is worth to you. My definition of easy comes from over 30 years of fixing cars, Audi's are lot easier than some other makes and models but they are generally quite expensive in comparison.
    2003 A6 C5 2.5 TDI Quattro Avant (180bhp)
  3. Re: Suspension system inoperative
    Apr 2018
    sittingbourne
    Thank you for your reply. Providing the compressor is an easy fix and i do mange to get most of the work done myself, with the prices you mention i believe it may be possible to save my baby. May have had a stroke of luck last night finding a donor vehicle too.
  4. Re: Suspension system inoperative
    Aberdeen
    30 Post(s)
    Look for bagpipingandy on the forum. He sells kits to repair the compressor and has some great guides on how to do it. Loads of threads about these issues too. Best of luck.
    Current- S3 Sportback Nav S-tronic, Mythos Black, B & O, Comfort Pack, Lumbar Support, Lunar Silver interior.
    Gone-A6 C7 biturbo saloon, A6 C6 3.0 tdi Quattro saloon, A6 C5 2.8 Q Avant
  5. Re: Suspension system inoperative
    Jan 2013
    Wessex. and Southern France
    61 Post(s)
    second that.
  1. Slime in Air Suspension system - Audi C5 Allroad
    By r7ehw in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 13-04-2017, 08:45 AM
  2. Question 'AFS inoperative' (Adaptive Front-lighting System)
    By Gary Games in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 30-11-2013, 02:22 PM
  3. Question Warning 'beep' inoperative.
    By warptechno in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-05-2012, 07:19 PM
  4. AFS inoperative see owners manual
    By UkMark in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 03-07-2010, 01:47 PM
  5. audi symphony system inoperative
    By mr_brightside in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 15-12-2007, 07:27 PM
