Thread: P1020 High Pressure Fuel Fault Help
Results 1 to 10 of 10
  1. P1020 High Pressure Fuel Fault Help
    Oct 2014
    Binfield
    So this has been quite a long standing problem I have had on my 3.0TDI, but it has recently become undrivable! When under load (used to be full throttle now it is most of the time) I get a flashing coil light. If I do a scan, the fault I get is “Fuel Pressure Regulation Control limit exceeded Upper limit exceeded”. I have already replaced the high fuel pressure sensor on the LH rail and the high fuel pressure regulator on the RH rail.
    I know there is a flow metering valve on the back of the HPFP, so this is going to be my next target as it is the only thing left that hasn’t been replaced. This is getting expensive though, so wondered if anyone has seen a similar fault and how they fixed it?
    I have attached a scan below, and will try and make a data log when it happens.
    Date: 2018-10-06 13:20
    VIN: WAUZZZ8E55A506018
    Car: Audi A4
    Year: 2005
    Body type: Avant
    Engine: BKN 150 kW (204 HP) 3.0 l
    Mileage: 269190 KM
    01 Engine
    System description: 3.0L V6TDI G000AG
    Software number: 8E0910401F
    Software version: 0060
    Hardware number: 8E0907401AJ
    Coding: 0011171
    Trouble codes:
    P1020 - Fuel Pressure Regulation Control limit exceeded Upper limit exceeded
    static
  2. Re: P1020 High Pressure Fuel Fault Help
    Jan 2018
    Sussex
    50 Post(s)
    Did the flow metering valve fix it ?
    Current cars:
    2007 Passat b6 2.0 tdi BMR DSG
    2011 Golf MK6 1.6 tdi CAYC 5 speed
  3. P1020 High Pressure Fuel Fault Help
    Oct 2014
    Binfield
    Not got a new one yet, I have been away. I managed to pull the HPFP out on Monday as you have to remove it to get to the valve (much to my dismay as I had just put all the bumper back on, and to get the HPFP out it all has to come off to the service position)
    I’m going to give it a good clean out and test tomorrow. If not it appears to be about £100 for a replacement.
    I assume you have similar symptoms then, not a solution?
  4. Re: P1020 High Pressure Fuel Fault Help
    Jan 2018
    Sussex
    50 Post(s)
    No, never had to go further then rail pressure regulator valve, so interesting to see.
    Good luck !
    Current cars:
  5. Re: P1020 High Pressure Fuel Fault Help
    Oct 2014
    Binfield
    Quote Originally Posted by Renars View Post
    Good luck !
    Did you have to do adaptions after replacing it or was it just plug and play?
  6. Re: P1020 High Pressure Fuel Fault Help
    Jan 2018
    Sussex
    50 Post(s)
    I think it was plug and play !
    Current cars:
  7. Re: P1020 High Pressure Fuel Fault Help
    Oct 2014
    Binfield
    So I have sent this to a diesel injection specialist, their diagnosis, after also speaking to Bosch technical I s either the HPFP Fuel Intake Metering valve, which can be bought for about £100 or a software problem.
    I will update once I have replaced the valve, it has just come in today!
  8. Re: P1020 High Pressure Fuel Fault Help
    Oct 2014
    Binfield
    For anyone with this fault, replacing the metering valve on the back of the HPFP fixed it for me, now works flawlessly!
    They aren’t available for the A4 from Audi, however a VW crafter uses the same valve and they will sell it to you for ~£100.
    Audi/VW part #: 059 906 457
    Bosch part #: 0928400676
  9. Re: P1020 High Pressure Fuel Fault Help
    18 Post(s)
    460 Post(s)
    Very useful information, did you use the part numbers off of the old one to do this? 059 906 457 is £204.73 genuine so did you use one from Bosch?
  10. P1020 High Pressure Fuel Fault Help
    Oct 2014
    Binfield
    Internet research gave me this information, as Audi’s only advice was a whole HPFP! I just started searching for the part number that was printed on the valve.
    I ordered one through a company called Thames Valley Electro Diesels. eBay has many new ones listed though. Genuine Bosch units.
  1. High fuel pressure A6 2.0 tdi 170 ps
    By Sambor11 in forum VCDS - General Questions
    Last Post: 14-03-2016, 08:35 PM
  2. Please Help GT TDI 170, hesitation, High pressure fuel pump failure/fuel contamination
    By Bruceakm in forum Golf MK5 - 2004 - 2009
    Last Post: 05-03-2014, 08:50 PM
  3. High Fuel Pressure specified vs actual
    By busandcamper in forum VCDS - Help Requests
    Last Post: 08-12-2012, 12:26 AM
  4. High Pressure in Fuel Tank
    By I.T. in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 11-04-2011, 11:32 AM
  5. A/C high pressure sensor fault
    By badass76 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 16-01-2010, 06:13 PM
