Thread: 5120 - Oxygen (Lambda) Sensor B1 S1
  1. 5120 - Oxygen (Lambda) Sensor B1 S1
    Apr 2016
    London/UK
    23 Post(s)
    P2196 00 [237] - Signal too High (Rich)
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 9
    Mileage: 288065 km
    Date: 2018.09.29
    Time: 17:04:18
    engine light keeps coming on after clearing the codes and its staying on (not blinking)
    did you guys had this error before?
    i read about it and it can be because of: old plugs, lambda sensor, bad fuel.....
    in extreme cases can cause the CAT to catch fire
    i need a bit of advice before getting a 200 pound sensor
  2. Re: 5120 - Oxygen (Lambda) Sensor B1 S1
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    easiest and cheapest thing to check first is all the engine air intake system, wiring to the sensor, breather hoses etc for splits and leaks, although unmetered air admitted by a leak usually is indicated by lean output, check EGR valve operation as well, depends what sort of diagnostic tool you have ( that looks like VCDS) but you can graph the O2 sensor output voltage and see how its responding to changes. If the sensor is lazy not reaching full lean or rich voltage or responds slowly then it is probably at fault, there is info out there telling you what to look for.
  3. Re: 5120 - Oxygen (Lambda) Sensor B1 S1
    Apr 2016
    London/UK
    23 Post(s)
    Quote Originally Posted by Rob69 View Post
    i do have VCDS. how do you check all these you said?
    Just tried it on vcds
    I am getting this:
  4. Re: 5120 - Oxygen (Lambda) Sensor B1 S1
    Apr 2016
    London/UK
    23 Post(s)
    When I'm trying to get a egr test started, I'm getting " not running. Operate brake pedal and depress accelerator pedal"
    Don't know what to do here.. .
  5. Re: 5120 - Oxygen (Lambda) Sensor B1 S1
    Apr 2016
    London/UK
    23 Post(s)
    Quote Originally Posted by johnro79 View Post
    Managed to do the tests . Valve is working
  6. Re: 5120 - Oxygen (Lambda) Sensor B1 S1
    Nov 2010
    104 Post(s)
    so can you bring up a VCDS scope and see how the O2 sensor voltage is reacting?
  7. Re: 5120 - Oxygen (Lambda) Sensor B1 S1
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    look at short and long term fuel trims
    Alan.
    VW T6 150 DSG Camper £££
  1. Question Oxygen/Lambda sensor location 3.2 V6
    By gokiwi64 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 23-03-2017, 06:31 PM
  2. Please Help Drinks too much diesel :( Lambda/Oxygen Sensor)
    By Zeb in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 10-03-2011, 07:08 PM
  3. oxygen sensor(lambda) 1.8T petrol
    By gazzap in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-05-2009, 09:31 PM
  4. Lambda / Oxygen sensor for S4...
    By Senlisian in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 13-11-2008, 12:38 AM
  5. Oxygen/Lambda sensor
    By dazaudi in forum 80 - 90
    Last Post: 04-04-2007, 07:10 PM
