Thread: What's going on with these spark plugs ?
  1. What's going on with these spark plugs ?
    Oct 2018
    Havant
    Hi I've been having a misfire issue with my a4 b5 1.8t ajl engine code had ruled out plugs as they are relatively new however I decided to change them and it solved the issue upon inspecting them it looks like they've been arcing out ?
    What would be causing this?
    specs are as follows
    1.8t ajl engine
    K04 015 turbocharger running 1.5 bar
    Saab red top 360cc injectors at 4 bar
    Tfsi coil pack upgrade with icm delete
    3inch decat into milltek non res 2.75 inch system
    Large front mount intercooler
    Vr6 Maf with large intake pipe
    Plugs are bkr7e
  2. Re: What's going on with these spark plugs ?
    Oct 2018
    Havant
  3. Re: What's going on with these spark plugs ?
    Mar 2016
    Minervois, France
    53 Post(s)
    If you are referring the signs of tracking down the insulator, this could be due to the plug electrode gaps being too large, or damaged/cracked/faulty ceramic insulators.
    Did this forum help you? Help make sure it's here next time! Follow the instructions at the top of the page to make a suitable donation using PayPal .
    1996 A4 B5 (S2) Avant 1.8T (petrol) 150 bhp code AEB automatic with 79,125 kms = 49,450 miles on 30/07/23
    VW T25 Camper, Alfa 33 1.4 ie, 2 Alfa 33's for parts.
  4. Re: What's going on with these spark plugs ?
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    It looks like its been running too hot with burnt eroded insulator, I'm not a plug expert or tuning fanatic but the bkr7e looks like a pretty standard plug for your modded engine ?maybe you need to look at a colder plug or higher spec ?
  5. Re: What's going on with these spark plugs ?
    Feb 2016
    Blaydon, North east England
    53 Post(s)
    Did you gap the plugs before you installed them?
    Common practice to check the gaps even on new plugs.
    2015 A6 Allroad 3.0TDi 218 CRTE - NEW
    2012 A6 Avant 3.0TDi Multitronic - OLD
  6. Re: What's going on with these spark plugs ?
    1837 Post(s)
    Dangerously lean, you are one step cooler there, maybe time to move another step cooler but add some fuel. I find on cars like this that an in dash AFR meter such as an AEM UEGO is extremely helpfull.
  1. Question Which Spark Plugs ?
    By belfastmark in forum Golf MK4 - 1999 - 2004
    Last Post: 14-09-2009, 05:48 PM
  2. A4 Cab 2.4 (BDV) best spark plugs
    By wmccann in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 05-07-2009, 07:21 PM
  3. spark plugs?
    By joz119 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-06-2009, 04:48 PM
  4. What's up with my spark plugs?
    By cadnr in forum Golf MK3 - 1993 - 1999
    Last Post: 17-09-2008, 05:28 PM
  5. Spark plugs
    By xerian in forum Beetle 2000-
    Last Post: 27-01-2008, 06:09 PM
