Thread: What gearbox's will fit my car. HELP!
  1. What gearbox's will fit my car. HELP!
    Jul 2011
    Lancs
    Hello, Im looking for some information with regards to which gearbox's will fit my 2006 Passat 1.9tdi - It currently has the HNV gearbox fitted which has pretty much destroyed itself, It is also a BKC engine, im wondering do i have to specifically fit a HNV stamped box, or will other ones fit. Many thanks in advance. Nic.
  2. Re: What gearbox's will fit my car. HELP!
    Jan 2012
    Rustington, West Sussex UK
    45 Post(s)
    Quote Originally Posted by pelicanquattro View Post
    Yours a 5 or 6 speed? If 5 speed, the most common pairing, then a JCR or GQQ should fit. If you want to you can 'upgrade' to a 6 speed but there are only one or two that fit with compatible gear ratios and clutch / flywheel sizes like those from a 2007 Touran.
    Mad Mitch
  3. Re: What gearbox's will fit my car. HELP!
    Jul 2011
    Lancs
    Hi mitch. Its a 5 speed. Im looking to keep it the way it is to be honest. Its just a bit of a workhorse for me. So a JCR or GQQ box will be ok then. Im taking your word for it!! Nick.
  4. Re: What gearbox's will fit my car. HELP!
    Jan 2012
    45 Post(s)
    Your options are not limited to just those two either Nick, as there are nearly a dozen boxes fitted to the VAG 1.9 engine range but these two are quite common and easy to source.
    Mad Mitch
  5. Re: What gearbox's will fit my car. HELP!
    Jul 2011
    Lancs
    Thanks very much for the info Mitch.
  1. Question Looking for multitronic gearbox will only one code gearbox work
    By yaza01 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 01-10-2017, 03:39 PM
  2. Gearbox - No reverse, rattle in neutral- leaking gearbox oil. HELP!!!!!
    By robert1z in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 14-03-2017, 07:00 PM
  3. 2.0 tdi Gearbox Transmission oil spec & amount for GYX gearbox ?
    By niall campbell in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 15-09-2015, 03:08 PM
  4. Replies: 1
    Last Post: 15-02-2015, 05:39 PM
  5. Gearbox DFH, will it fit replace my gearbox DFK?
    By red_avant in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-10-2008, 05:32 PM
