Thread: Audi A4 s-line rear coil springs???
  1. Audi A4 s-line rear coil springs???
    Mar 2009
    Has anyone ever had trouble buying rear springs for an 2008 Audi A4 S-line 2.0 TDi?. I work in a a garage and all the springs listed for this model from our motor factors are the wrong size. I just cannot seem to find the right ones anywhere. The measurements listed for the car are approx 290mm in height and approx 135mm width across the middle. The ones i have on the car which look original (with grey and blue paint dots) are approx 250mm height and approx 115mm wide. The bigger ones will not sit right and hit against one of the arms. If anyone has had this problem and know the spring i need, i would appreciate your help. Thanks in advance. Gary.
  2. Re: Audi A4 s-line rear coil springs???
    Jan 2009
    Birmingham
    35 Post(s)
    count the EXACT colour marks on the spring and post on here i try get the part number for you
  3. Re: Audi A4 s-line rear coil springs???
    Sep 2018
    Check here out, may help
  1. A6 2.7 avant rear coil springs
    By steffan279 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 08-04-2013, 08:08 PM
  2. Standard rear coil springs on a sport TDI
    By Chrisman in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 31-05-2012, 02:34 PM
  3. Replacing rear coil springs on 99 Bora
    By leblebia in forum Bora - 1998 - 2005
    Last Post: 09-06-2011, 08:08 PM
  4. Question Rear Coil Springs
    By The Technician in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 17-01-2011, 01:04 PM
  5. Rear Coil Springs
    By djmx5 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 07-10-2009, 07:06 PM
