Thread: Please Please Help - urgent - coolant leak
  1. Please Please Help - urgent - coolant leak
    Jun 2015
    Essex
    So I was topping up my oil this evening and noticed what appears to be a coolant leak from the reservoir to the radiator, please see picture.
    I checked the reservoir level and it is about 1cm above the min (see other pic), not sure what is was previously though as it is not something I usually pay much attention to. Car was last serviced about 6 months ago.
    Obviously i need to get this sorted out, however tomorrow I am due to drive to Leeds and back which is a 400 hundred mile round trip and I worried that there is a possibility I could break down.
    So not sure what to do? Any advice would be gratefully received.
    Regards
    Simon
  2. Re: Please Please Help - urgent - coolant leak
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    That looks like a crusted up weep rather than an ongoing steady leak, if you wipe your finger round it, is it constantly wet or dripping while the engine is hot and running? since you still have a reasonable level in the reservoir and it hasn't been checked in 6 months, I suspect it is a very slight leak. I'd say it will probably be ok on your trip, if you top up the coolant now to max and check it a few times during your journey i reckon you'll be ok, but can't give any guarantee !!!
  3. Re: Please Please Help - urgent - coolant leak
    Jun 2015
    Essex
    Quote Originally Posted by Rob69 View Post
    Thanks Rob, sadly I don't have any coolant, I plan to take some water with me in case of emergency I think it ok to use some of that?
    I will keep an eye on the level and if neccessary have to stop at Halfords or similar and buy a bottle.
    Would this be ok
    Mine currently has G12.
    Halfords OAT Ready Mixed Antifreeze...
  4. Re: Please Please Help - urgent - coolant leak
    Nov 2010
    104 Post(s)
    you'd be ok to top it up with water if you intend to get the leak repaired in the near future, before we get into winter proper. Top up to max before you start the journey. If for any reason though you run low on coolant while driving and the engine overheats do not add cold water into the hot cooling system as this can crack cylinder head etc, let things cool down for an hour or so. A small volume of water will not dilute the antifreeze too much and as the coolant will need to be drained and refilled to fix the leak permanently it should be refreshed back to full strength at that point. If you can get it, that red antifreeze mix will be ok as well, although IMO preferable to use the proper G12 (now G13) coolant if you can and depending how fussy you are !
    Have a good trip and weekend.
  5. Re: Please Please Help - urgent - coolant leak
    Jun 2015
    Essex
    Thanks for your advice
    Made it to Leeds, hopefully make it back!!
  1. 1.9TDI (BKC) Fuel Pump Leak & Coolant Leak.
    By DannyBoyGolf in forum Golf MK5 - 2004 - 2009
    Last Post: 16-07-2018, 10:51 PM
  2. Question Coolant leak from rear flange: Sourcing the coolant pipe?
    By defever in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-09-2015, 11:36 AM
  3. Important Urgent help needed....coolant leak and a weird ticking noise.
    By rossmc in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 04-12-2011, 10:05 PM
  4. water Leak (URGENT)
    By jonburt88 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-06-2009, 10:20 AM
  5. Please Help Coolant Leak From Coolant\Water pump Housing
    By Chappio in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-04-2009, 03:30 PM
