Thread: Rear Spring replacement
  1. Rear Spring replacement
    Oct 2014
    Leeds, West Yorkshire
    Hi all,
    I've searched online and not really found anything definitive. My question is - Is it possible to replace the rear springs on an Audi A6 C6 without the one sided spring compressors. I do have spring compressors but read you need the type that have the disc that sits on the spring coil and attaches on only one side.
    or could you undo the control arms and drop the spring that way?
  2. Re: Rear Spring replacement
    Oct 2014
    Anyone?
  3. Re: Rear Spring replacement
    Oct 2014
    Not one person has replaced or had replaced their rear springs?
    disappointing.
  4. Re: Rear Spring replacement
    Aug 2016
    Cape Town, South Africa
    All I see in Elsawin is the process you describe which uses the factory tools and compressor.
    If I were you, I would look for aftermarket spring manufacturers fitting manuals on their websites. They should show how to remove the factory and replace their aftermarket lowering/sport spring.
    2006 A6 Avant 3.0 TDi Quattro
  1. Audi C6 2008 rear spring and front drop links replacement
    By Strath44 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 14-03-2016, 01:38 PM
  2. rear spring has broke again
    By hunterczt in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 21-07-2015, 01:35 PM
  3. MK2 rear suspension replacement. spring compressors?
    By randombadger in forum Ibiza - Cordoba
    Last Post: 23-05-2012, 09:39 PM
  4. Coil Spring Replacement
    By shegan in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 21-01-2011, 10:36 AM
  5. A8 non quattro Rear spring replacement!!
    By Chris28v6 in forum A8 - S8 - V8
    Last Post: 02-02-2010, 11:23 PM
