Thread: Front brake pads and discs
  1. Front brake pads and discs
    Feb 2012
    Essex
    7 Post(s)
    Hi guys. I haven’t posted on here for ages but have still been reading through all the posts.
    I’ve just had my two year service at 19000 miles. Quite an expensive week so far with the service, 4 new tyres, wheel alignment and camber fix. I’ve had an advisory regards the front brakes. Pads and discs both 75% worn. I would look at using an independent garage for the work based on my dealer’s quote.
    Whilst I get it’s a big car and I understand that pads may have worn, I’ve never known a set of discs to wear at the same rate as a set of pads.
    Am I unrealistic to think this? Have any of you guys that have got to 2 years or 20k had similar advisories or needed to change the discs?
    The car is mostly driven by the missus (very slowly ......... ha ha) and we don’t have or use ACC.
    Any views would be massively appreciated.
    Thanks.
  2. Re: Front brake pads and discs
    Jul 2016
    Munich
    Quote Originally Posted by Thakey17 View Post
    Thanks.
    Yes, front braken were replaced at 30k...then front and back again at 65k...they are basically worthless in my opinion.
    I also saw Audi now offers ceramic brakes on the Q7 2019 model (at least in Germany)...makes sense when you see how quick the normal brakes need to be replaced.
    Verzonden vanaf mijn iPhone met Tapatalk
  3. Re: Front brake pads and discs
    Feb 2012
    Essex
    7 Post(s)
    Thanks Sven.
    I saw someone refer to the brakes being made of cheese on an earlier post. I think there could be a lot of truth in this...... ha ha.
  4. Re: Front brake pads and discs
    Apr 2016
    berkshire
    39 Post(s)
    Probably doesn't help.. But I'm guessing substandard materials couk now be in use as part of the the manufacturing line..
    The list of tacky stuff on the new Q7 as apposed to older version is far greater on this one than the previous version Q7 IMO..
    Sent from my STF-L09 using Tapatalk
  5. Re: Front brake pads and discs
    Jul 2016
    Munich
    Quote Originally Posted by satyp View Post
    The brake pads are just way too tiny for such a heavy car. I guess it has to do with wanting weight reduction over the predecessor, and as such lowering the emissions...
  1. Front Brake Pads and Discs Change
    By mrsudia6 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 15-05-2018, 02:44 PM
  2. Front Brake Discs/Pads
    By amantadine in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 26-11-2013, 05:31 PM
  3. Important New Brake Discs & Pads (Front)
    By A4 FSI in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 24-07-2013, 03:30 PM
  4. Question Bora brake discs and pads ( front )
    By redtony in forum Bora - 1998 - 2005
    Last Post: 17-12-2009, 04:44 PM
  5. Changing front brake pads and discs
    By KevBrowne in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 03-01-2008, 10:39 PM
