Thread: BiTdi Auto Service
Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
  1. Re: BiTdi Auto Service
    #21
    May 2009
    Ramsey, New Jersey, USA
    69 Post(s)
    Quote Originally Posted by Renars View Post
    You just made clear what I already knew - Dealers in UK are terrible.
    Don't go to them !
    Really? One bad experience with one dealer means all dealers in the UK are terrible? Really?
    My local dealer has given me outstanding service over the last 18 years and seven different Audi cars I have entrusted to their care.
    By the same logic you're using, this implies all dealers in the UK are brilliant.
    The reality is there are some great dealers and some not-so-good dealers. You can't tar them all with the same brush.
    Just my tuppence
    MF.
    Now: E 53 AMG 4MATIC
    / Q5 2.0TFSi Prestige
  2. Re: BiTdi Auto Service
    #22
    Jan 2013
    Wessex. and Southern France
    108 Post(s)
    Yeah, let's not use dealers to service our new cars, let's use, I don't know, ah, let's use the post office. I'm sure they can handle the technical side, plus All the warranty work.
  3. Re: BiTdi Auto Service
    #23
    Jan 2018
    Sussex
    55 Post(s)
    Quote Originally Posted by MFGF View Post
    Just my tuppence
    MF.
    What problems you have had with your cars ?
    They all are great to do overpriced maintenance that's for sure.
    Actually you are right its not UK, its EVERYWHERE.
    Just had 2012 Touran which has auxiliary heater to support it while car heats up, not electric one.
    Found out with VCDS unit is locked.
    You want to know when to this error was dated ?
    It was october 2012, car serviced by dealer in Munich, Germany for last 260 000 km and 6 years.
    Owner obviously didn't know about heater error.
    Otherwise great car, nothing had failed, Original clutch, DMF, DPF, injectors, turbo everything.
    And it was mostly on 30 000 km ''longlife'' oil service
    Top engine mount was starting to wear and made engine vibration in low RPM in low load condition, but cheap fix.
    Also no DPF problems as Autobahn driving makes them last long.
    No stupid emission fix done.
    Whats the point to go to dealer if they just don't care and service they provide is like that.
    You are not supposed to know it had some errors, dealer has to check, but they didn't.
    Lucky you to have good dealer nearby, or just having good cars...
    Current cars:
    2007 Passat b6 2.0 tdi BMR DSG
    2013 Golf MK7 1.6 tdi 5 speed
  4. Re: BiTdi Auto Service
    #24
    May 2009
    69 Post(s)
    It isn't that I have had good cars. I have had some issues over the years:
    A6 MMI 3G radio/TP/TMC problem
    The above is a 27-page thread detailing what turned out to be a software fault in one of my previous A6s. If you spend an hour reading through it, you will see my dealer did everything they could to help, and gave me a free map update after the car was fixed. I give them huge credit. I can attest that not all dealers are bad - I hope you manage to find a good one eventually
    Cheers!
    MF.
  5. Re: BiTdi Auto Service
    #25
    Jan 2018
    Sussex
    55 Post(s)
    Happy to see your dealer can fix radio, but you have been quite lucky with cars then.
    Current cars:
  6. Re: BiTdi Auto Service
    #26
    Jul 2012
    Staffordshire, UK
    I do believe dealers are a mixed bag as well. I had an issue on my A6 after Stoke Audi serviced the DSG gearbox - it completely died after a short drive and left me stuck in the middle of a busy roundabout at peak time evening traffic.
    To be fair to them, it could have turned into a huge legal fight but they rectified the situation very well. My car was collected straight away by them within 1 hour of a phone call the following morning. 2 hours later a brand spanking new Q5 with 20 miles on the clock was delivered - I ended up putting over 1000 miles on this car so they lost some value there. The Mechatronic unit on the gearbox was replaced with brand new and all of this at their cost. The amount of diagnostic work done and oil changes before replacement - the total labour time and parts had I been paying would have worked out around £5K in the end.
    Ok you could argue the job should have been done correctly in the first place but to me, how they made up for it shows the true signs of a dealership.
    0 2 0
  7. Re: BiTdi Auto Service
    #27
    May 2009
    69 Post(s)
    Quote Originally Posted by slackworth View Post
    Same dealer as me.
    MF.
  1. Question A6 BiTDI (2015) - First Service
    By hshah in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 11-04-2017, 11:49 AM
  2. Replies: 6
    Last Post: 25-10-2016, 10:33 PM
  3. Audi 90 auto box service
    By m4xmw in forum 80 - 90
    Last Post: 21-06-2012, 12:01 AM
  4. Major Service (40k) for Auto 2.7 V6 TDI B8 Prices
    By simonhouse in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 21-01-2011, 10:14 PM
  5. Please Help Auto Airconditioning Service Glasgow
    By abolt in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-06-2010, 03:41 PM
