Thread: major problem with my A4 B6 2003 2.5tdi Quattro Avant..engine code ake
  1. major problem with my A4 B6 2003 2.5tdi Quattro Avant..engine code ake
    Oct 2018
    Uk
    hi all , im needing some advice,
    My A4 stopped running a couple of weeks ago and hasnt ran since other than a short "vroom" via a squirt of easy start into the air filter to assertain some sort of idea as to whether its a mechanical or electronic failure.. i bought a Ross Tech vag com diagnostic system last week and a toughbook to run it on today (as i only use Macs normally ) so's to cut down on "plug it in costs " at the garage..
    there were no symptoms what so ever , just stopped running, no engine light or malfunction notice , was running perfectly ..
    so using the vag com today i have a list of fault codes that have come up, which in my very novice opinion, from what ive read about over the past couple of weeks points to an injection pump failure or i'm hoping a connection failure of some sort, as everything was working fine, nothing to say anything was wearing out or due to fail ..
    00542- needle lift sensor (g80)- 38-10 open or short to plus - intermittent
    17583- pre-injection turned off p1175-35-10-intermittent
    00550- start of injection regulation 27-10-implausible signal - intermittent
    00532- supply voltage B+ 07-10 -signal to low - intermittent
    i'd be thankful for any advise on what this could be .. regards Fred
  2. Re: major problem with my A4 B6 2003 2.5tdi Quattro Avant..engine code ake
    1835 Post(s)
    Those VP44 pumps are nothing but trouble, before we had the ability to rematch the immobiliser we would always give them to a Bosch agent near us to repair as they kept the coding in most cases but now I we have ODISwe can buy them off the shelf.
  1. A4 2.5TDi SE Avant 2003
    By laddie18 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-10-2018, 04:29 PM
  2. Please Help 3.0l TDI engine code CDYA 2010 A6 le mans quattro low coolant problem
    By Garry_M in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 14-08-2014, 11:03 AM
  3. Audi A6 Avant 1999 2.5Tdi - Major issues with Engine/Gearbox
    By brodies in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 01-08-2012, 05:47 PM
  4. Question Tyre Pressures 2003 A4 2.5TDi Quattro Avant Michelin 235/40 ZR18(95Y) PS3
    By friendlyskies in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 11-06-2012, 10:31 AM
  5. 2003 A4 2.5tdi Quattro Avant - Reverse light problem
    By theminiman2002 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-01-2011, 10:40 AM
