Thread: Ibiza 1.4 petrol 2009 air bag light on
  1. Ibiza 1.4 petrol 2009 air bag light on
    Nov 2008
    Hi, we have a recently acquired 2009 (new shape) 1.4 petrol Ibiza. The air bag light came on yesterday. Tried to read the code today but no code there and the scanner can't access the SRS (it does access everything else). Checked the fuse and it is OK BUT there is no voltage supply on the supply side of the fuse. Which would explain why the scanner can not "see" the SRS system.
    Has anyone got any ideas please? Thanks.
  2. Re: Ibiza 1.4 petrol 2009 air bag light on
    1840 Post(s)
    The scanner you are using is not suitable, it needs a proper VAG specific system such as VCDS.
    1 1 0
  3. Re: Ibiza 1.4 petrol 2009 air bag light on
    Nov 2008
    Thanks. Just to confirm back - the car went on a VCDS scanner and it was a simple reset that was needed - so the type of scanner is indeed crucial.
    Turns out that the air bag light was triggered when the passenger air bag was inadvertantly disconnected and reconnected when some other work was being done.
  4. Re: Ibiza 1.4 petrol 2009 air bag light on
    1840 Post(s)
    That is why the book of words tells you to disconnect the battery when working on the air bag system, or at least don't turn on the ignition
    1 1 0
  1. A4B8 2009 Petrol door issue
    By Caro in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 24-10-2017, 12:19 PM
  2. Replies: 2
    Last Post: 15-07-2017, 02:34 PM
  3. Replies: 2
    Last Post: 10-03-2012, 12:44 PM
  4. Question Where is the diagnostic port located on 2009 (6j) Ibiza
    By KathW in forum Ibiza - Cordoba
    Last Post: 02-03-2010, 02:20 AM
  5. 2009 Ibiza
    By Fourbears in forum Ibiza - Cordoba
    Last Post: 17-05-2009, 10:51 PM
