Thread: help with heater blower please
Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 57
  1. Re: help with heater blower please
    #21
    1837 Post(s)
    Just noticed that this is a UK registered car **11 *TF, I thought you were in NZ.
    According to the Pr code list you have KH6 Climatronic
    The fan is powered from fuse SC38 on the dash right hand side when you open the door, behind the panel.
    Also check fuse SC15 which is the control unit power.
    Fuse SC38 is powered by two different methods depending on build date and this change is described as “gradual introduction” which is about as much help as a blower that does not blow! The change is only visible by checking the colour coding of the 6mm˛ csa cable to the SC fuse board line 30a rail to see if it is black or red/green and that is not easy to do.
    On both versions the feed is from a junction point called B319 which is also helpful described as being “in main wiring harness”, no ****, I thought it would have been under the back bumper! Stupid diagrams!
    The junction B319 also supplies the J59 relay also known as the X relay but J59 only powers fuse SC40 and not the fan so X circuits not working are a symptom of the X relay not being supplied (as opposed to triggered) and not the X relay itself being faulty. If fuse SC40 has no power from the X relay then the front and rear wipers won’t work
    B319 is supplied from fuse SB29 in models with the E-Box low like yours so check this has power.
    Check that lot, I need to get on now.
  2. Re: help with heater blower please
    #22
    Sep 2018
    BISHOP AUCKLAND
    i am really greatful for the reply crasher but honestly i have no idea what any of it means, electrics are way over my head.
    can anyone on here decipher crashers brilliant description and tell me exactly which fuse i need to check ?
    sc38 and sc15 seem to be the ones that need checking but can anyone tell me which ones these are ?
  3. Re: help with heater blower please
    #23
    Sep 2018
    BISHOP AUCKLAND
    i cant find any diagram anywhere for the fuse number locations for my b7 passat.
  4. Re: help with heater blower please
    #24
    Sep 2018
    BISHOP AUCKLAND
    Ok, I have replaced them 2 fuses, 1 is 10amp the other is 40 amp but fan is still not working.
    When I turn the heat knob I can hear motors moving but the fan does nothing.
  5. Re: help with heater blower please
    #25
    May 2007
    17 Post(s)
    Quote Originally Posted by whiteakita1 View Post
    Yeah, he is basically telling you what I already said....check the power supply to the fuses.
    If you find there is no 12v power supply to SC38, check the fuse that supplies power to SC38, which is...."SB29 in models with the E-Box low like yours". E-Box is Volkswagen speak for engine bay fusebox.
    Fuse locations are shown at the link in post #8 .
  6. Re: help with heater blower please
    #26
    Sep 2018
    BISHOP AUCKLAND
    Any help please crasher on which/where the X relay is so I can change it.
  7. Re: help with heater blower please
    #27
    Sep 2018
    BISHOP AUCKLAND
    I have removed/checked every single fuse I can find and they are all ok.
  8. Re: help with heater blower please
    #28
    Sep 2018
    BISHOP AUCKLAND
    Fuse sc38 has no power, which fuse in the engine bay powers that ?
    I
  9. Re: help with heater blower please
    #29
    Sep 2018
    BISHOP AUCKLAND
    Which one is sb29?
  10. Re: help with heater blower please
    #30
    Sep 2018
    BISHOP AUCKLAND
    Ok I found sb29 and swapped it with the identical fuse next to it and nothing has changed.
    I still have no power to sc38.
    Heater fan and windscreen washers don't work.
    Wipers do work.
    What have I got left to check ?
  1. Help Heater Blower
    By philfire in forum Golf MK4 - 1999 - 2004
    Last Post: 11-03-2011, 07:31 PM
  2. Heater blower
    By raymondbilko in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-10-2010, 11:23 PM
  3. Please Help heater/blower
    By bs3 golf in forum Golf MK3 - 1993 - 1999
    Last Post: 17-01-2010, 10:44 PM
  4. 98 A6 Heater Blower!!!!!NOT..
    By fenboy in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 08-03-2009, 11:07 PM
  5. NO HEATER BLOWER
    By EMILY in forum Passat - Archive Topics
    Last Post: 23-01-2007, 05:38 PM
