Thread: 1.6tdi mk7 heater pump blocked
Results 1 to 10 of 11
  1. 1.6tdi mk7 heater pump blocked
    May 2009
    daventry
    All had our golf come up with p1 6c700 heater support pump blocked..
    Not 100% sure so thought id ask id this definatley the water pump oris there an additional circukation pump that im missig somewhere??
    Any advice appreciated....
  2. Re: 1.6tdi mk7 heater pump blocked
    134 Post(s)
    2021 Post(s)
    The CAYC engines have three water pumps, an electronically controlled engine driven pump and two electric pumps, one for the intercooler and another one hanging down the back of the engine for the heater. The MQB heater matrix is useless and they block easily, we are starting to get a lot of MQB cars with no heat, last Friday we did an early 8V A3 and the matrix was blocked. When the cooling system is opened, say to replace the pump, it MUST be bled using a diagnostic system or it will cavitate.
  3. Re: 1.6tdi mk7 heater pump blocked
    May 2009
    daventry
    Thanks crasher any idea on which is the most likely suspect the engine water pump seems to be the only one the main dealer showed for the vehicle...
    Dont want to chuck a new engine coolant pump at it if its something else.
    As far as im aware the cabin heater was working without issue...
    Car has done just about 38k so id hope its not a blocked heater matrix or similar.
    Im guessing the most likely is the cabin heater pump but not found a part number for it online as yet....
  4. Re: 1.6tdi mk7 heater pump blocked
    134 Post(s)
    2021 Post(s)
    Private message me your REG number please
  5. Re: 1.6tdi mk7 heater pump blocked
    May 2009
    daventry
    Hi Crasher
    Thanks for the response will do.
  6. Re: 1.6tdi mk7 heater pump blocked
    134 Post(s)
    2021 Post(s)
    To complex for my iPad, prod me tomorrow at work.
  7. Re: 1.6tdi mk7 heater pump blocked
    May 2009
    daventry
    Ok thankyou
  8. Re: 1.6tdi mk7 heater pump blocked
    May 2009
    daventry
    You have pm
  9. Re: 1.6tdi mk7 heater pump blocked
    134 Post(s)
    2021 Post(s)
    Its Service Diagnose Code (SDC) is V488 and that is used to identify the component inside VW, the electric pump for the intercooler is V188
    I wish I had taken a picture of the one I did a few weeks ago.
    I will try and look tomorrow.
  10. Re: 1.6tdi mk7 heater pump blocked
    134 Post(s)
    2021 Post(s)
    I think you will have to take the old one off the see which make it is.
  1. Question Audi A1 1.6tdi Supplementary Heater VCDS Location
    By Rich1408 in forum VCDS - Help Requests
    Last Post: 24-10-2016, 11:33 AM
  2. Important caddy 1.6tdi secondary air pump location
    By luigino007 in forum The Commercial Range
    Last Post: 06-12-2015, 07:56 PM
  3. Water Pump on a 1.6tdi mk6 Golf
    By matthew2riches in forum Golf MK6 - 2009 - 2013
    Last Post: 30-06-2013, 08:07 AM
  4. Auxilary heater seem to work but gets blocked
    By snorhyvel in forum Touran - Sharan - Caravelle
    Last Post: 07-04-2013, 11:07 AM
  5. How do you flush a heater matrix or tell if its blocked?
    By wibers in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 15-12-2008, 08:32 PM
