Thread: Help running Throttle Body/Valve Alignment
Results 1 to 8 of 8
  1. Help running Throttle Body/Valve Alignment
    Oct 2014
    London, UK
    9 Post(s)
    I’m hoping someone can help me....
    As some of you may have followed, I have recently done a full engine rebuild on my 3.0TDI after the timing chains jumped. Now as the last part of getting it back on the road I have a couple of niggly error codes, one of which relates to throttle valve position.
    I cleaned the throttle as part of the rebuild, so the likely culprit is that it just needs aligning. HOWEVER, every instruction I can find says to do the following:
    Turn the key on but do not start the car.
    [Select]
    [01 - Engine]
    [Basic Settings - 04]
    Group 060
    [Go!]
    It should say "Basic Settings: OFF" on the top of your screen.
    Click [ON/OFF/Next] to turn on Basic Settings.
    It should now say "Basic Settings: ON" on the top of your screen. Once you do this you will see the top right display say ADP RUN. The TB adaptation is being done as soon as you switched basic settings on. You will see the values change and hear the TB cycle for the first few seconds then it will stop. Leave it in Basic Settings for about 30 seconds.
    Click [ON/OFF/Next] to turn off Basic Settings.
    It should now say "Basic Settings: OFF" on the top of your screen
    Click the [Done, Go Back] button and you're all set.
    If I try and do this procedure, when I to go to channel 060 in the engine module I just get an error and I cannot run the alignment. I have read that you need to be clear of any ECU fault codes for it to run, but I have a couple of fault codes for the throttle activation failed that come back straight away even after I clear them, so I am kind of stuck in a cycle.
    I am using OBDeleven to try and run it and it can communicate with the car fine, I have coded other modules no problem. The procedure is also the correct one as the ECU is using KWP2000 to communicate.
    Has anyone successfully run the TBA on a 3.0TDI using OBDeleven? Do I need to put in a readiness code first? How do I get it to run? Any and all suggestions will be appreciated as I have run out of ideas!
    Scan as below:
    OBDeleven data log
    Date: 2018-09-22 11:48
    VIN: WAUZZZxxxxxxxxxx
    Car: Audi A4
    Year: 2005
    Body type: Avant
    Engine: BKN 150 kW (204 HP) 3.0 l
    Mileage: 269190 KM
    01 Engine
    System description: 3.0L V6TDI G000AG
    Software number: 8E0910401F
    Software version: 0060
    Hardware number: 8E0907401AJ
    Coding: 0011171
    Trouble codes:
    P3243 - Throttle valve control module activation Electrical error Lower limit not reached
    static
    P0638 - Throttle Actuator Control (Bank1) Range/Performance Lower limit not reached
    static
  2. Re: Help running Throttle Body/Valve Alignment
    Oct 2014
    London, UK
    9 Post(s)
    Has nobody ever run it?
  3. Re: Help running Throttle Body/Valve Alignment
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    Ross tech wiki video shows cycling the ignition when the error codes are displayed, then click on delete codes to erase them. I dont know if you have tried this or if it will work in your case.
    Alan.
    VW T6 150 DSG Camper £££
  4. Re: Help running Throttle Body/Valve Alignment
    Oct 2014
    London, UK
    9 Post(s)
    Played around with it yesterday. Turns out you only need to align a petrol throttle body. Diesels don’t need doing.
    Also the MAP sensor and throttle have exactly the same plug and are next to each other..... they don’t work plugged in the wrong way round.....
  5. Re: Help running Throttle Body/Valve Alignment
    1836 Post(s)
    Been there, done that, got the T shirt....
  6. Re: Help running Throttle Body/Valve Alignment
    Oct 2014
    London, UK
    9 Post(s)
    Well that’s 2 dead MAP sensors, third time lucky I suppose!
  7. Re: Help running Throttle Body/Valve Alignment
    1836 Post(s)
    Things like that make you want to scream, it is like someone is trying to test your patience and to see how far you will go, all I can tell you that is after nearly 40 years of going through this **** it does not get any better. The cars of the future will change things though as an owner or unqualified person will not be allowed to work on their own or anyone’s else’s cars without certificated training and if you do it without and screw up, you had better hope your mistake was fatal for you.... The days of DIY car maintenance are numbered.....
  8. Re: Help running Throttle Body/Valve Alignment
    Nov 2008
    20 Post(s)
    Funny you mentioned that, thats what it said on the video!
    Alan.
  1. Please Help Throttle Body Alignment
    By jamin128 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 05-03-2014, 08:02 PM
  2. What is (TBA) Throttle Body Alignment
    By Dave_Bounce in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 06-03-2013, 06:51 PM
  3. Clean throttle body and perfom Throttle Body Alignment (TBA) - big job?
    By allanmb in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 31-01-2013, 09:50 PM
  4. Throttle body alignment, not doing anything
    By ezhik in forum VCDS - Help Requests
    Last Post: 24-12-2008, 04:38 PM
  5. Throttle Body Alignment
    By preb1 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 20-12-2008, 09:01 PM
