Thread: A6 Allroad 4G 3.0 TDI (2013) Drive Train
  1. A6 Allroad 4G 3.0 TDI (2013) Drive Train
    Aug 2018
    Winchester
    Hi There !
    I have been struggling with a vibration coming from the front right wheel of my allroad.
    All wheel balancing, tire and brake issues have been ruled out.
    Next Wednesday I will be taking the car to the dealership for a potential Drive Shaft replacement.
    Has anyone had this part replaced? Under witch symptoms? I am being recommended to replace the whole thing + wheel bearing.
    Thank You
    Best Regards
  2. Re: A6 Allroad 4G 3.0 TDI (2013) Drive Train
    Aug 2009
    Usa
    6 Post(s)
    98 Post(s)
    Its rare to have a faulty driveshaft. Inner and outer cv joints are wear n tear items and its the norm to replace those. Ive only ever replaced these on cars ive known to have some accidental damage to its side
  3. Re: A6 Allroad 4G 3.0 TDI (2013) Drive Train
    Aug 2018
    Winchester
    Thenk you for the reply !
    I suspect there was some damage that caused this.
    The cost of both CV joints is almost the same as the whole thing.
    My doubts are on the simptoms it might cause.. chassis vibration on that side , specially when turning over that wheel.
    BEst regards
  4. Re: A6 Allroad 4G 3.0 TDI (2013) Drive Train
    Aug 2009
    Usa
    6 Post(s)
    98 Post(s)
    I suggest you find a good quality used one from a low mileage car. Check ebay for used parts. Unless Audi dealer is confirming 100% that a new driveshaft will rectify the issue.If not dont pay us. Then fine use them.
  5. Re: A6 Allroad 4G 3.0 TDI (2013) Drive Train
    Dec 2016
    Sussex, UK
    13 Post(s)
    could be the tyre pattern or a slightly buckled wheel casuing it too. Try swapping the wheels around to see if the problem moves with it.
  1. Drive train backlash
    By caldirun in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-01-2016, 10:16 AM
  2. Drive train problem
    Last Post: 13-01-2014, 09:34 AM
  3. Drive Train problem
    By caldirun in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 02-12-2013, 08:51 AM
  4. Question Knocking / play in drive train on take up
    By skymaster in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 13-08-2013, 05:21 PM
  5. Please Help Strange drive train judder
    By davey_boy in forum Golf MK4 - 1999 - 2004
    Last Post: 03-09-2010, 08:45 PM
