Thread: 97 Polo 16v (AFH) ECU reference?
Page 7 of 7 FirstFirst ... 567
Results 61 to 66 of 66
  1. Re: 97 Polo 16v (AFH) ECU reference?
    #61
    1840 Post(s)
    That will be a design revision
  2. Re: 97 Polo 16v (AFH) ECU reference?
    #62
    Jul 2018
    Funchal
    Hi ,do you know the size of the injectors orings, i wanted to change the ones that go into the intake collector but no one has them around or know they're size...
    And i thought these used only a top and bottom oring but this site states the injectors comes with 3 rings? Injector BOSCH 0 280 158 229 buy cheap online
    And looks like bosh discontinued the brow oring F 00V E24 012 do you know the replacement part number or size?
    Thank you
  3. Re: 97 Polo 16v (AFH) ECU reference?
    #63
    1840 Post(s)
    They are now made of an Ethanol resistant material under a new VAG part number of WHT 005 422 B but they are silly money, about 10 Euro each! The specification is listed as inside diameter 7.52mm outside diameter 14.58mm thickness 3.53mm. These are available from Elring under part number 893.889 and from Bosch as 1 280 210 752.
  4. Re: 97 Polo 16v (AFH) ECU reference?
    #64
    Jul 2018
    Funchal
    Hi, once again thanks a lot. I will try to find them around with the references you provided...
    Do you know if they're the same top and bottom since the bottom ones have a difrent colour?
  5. Re: 97 Polo 16v (AFH) ECU reference?
    #65
    1840 Post(s)
    Upper and lower are the same, the colour is the material identification, I think they are black now.
  6. Re: 97 Polo 16v (AFH) ECU reference?
    #66
    Jul 2018
    Funchal
    Hi Crasher.
    i could not find Elring ones but i found Bosch they first wanted almost 27euros i said i didnt expect that for 4 pieces of rubber they said hold on and gave me the final price of 12,44euros this was by phone, when i got there the packged was opened at the back and looks like it would have come with 5 pieces , but anyway i didnt said nothing just paid... Better than paying 27€
    http://
    will fit them at the weekend and see if it makes difference to the car behavior...
  1. 97 Polo 6N1 (AFH) Throttle body reference?
    By B600power in forum Polo - Derby - Lupo - Fox
    Last Post: 27-07-2018, 11:33 AM
  2. 2005 alhambra reference tdi-help needed please
    By harty2000 in forum Alhambra
    Last Post: 16-07-2014, 07:33 PM
  3. VCDS Reference values
    By johnvw in forum VCDS - General Questions
    Last Post: 03-03-2011, 09:12 AM
  4. Audi A4 air con reference mode
    By bags in forum New Member Introductions
    Last Post: 13-11-2009, 10:25 PM
  5. A4 Air con reference mode
    By bags in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 13-11-2009, 07:30 PM
