Thread: 97 Polo 16v (AFH) ECU reference?
Page 6 of 7 FirstFirst ... 4567 LastLast
Results 51 to 60 of 66
  1. Re: 97 Polo 16v (AFH) ECU reference?
    #51
    Jul 2018
    Funchal
    Hello [Crasher] I did a quick back pressure test (at idle) using the lambda hole before the Kat and i showed 0 back pressure , the car still has the same symptoms hiccups from 1200 rpm to 3000 clears after that but slow acceleration like its running rich, stalls at traffic lights or when coming to a stop...and failed mot for being too rich (high CO)
    i cant think of anything else unless its the ECU with the dodgy reference or the new distribuitor fitted by the P.O which has no brand on it other than this reference: 03090520AB ,from factory it should have had a bosch or marreli dizzy..?
    Other thing the injector have a blue band on it i remenber Reading na old post on the internet that the blue band injectors where fitted to gti's?
    I was surprised when the mot man said this car never failed mot before...
    Any thoughts on what i should look for next as i need to take it to mot again next monday..?
  2. Re: 97 Polo 16v (AFH) ECU reference?
    #52
    1841 Post(s)
    Are you still running the D version ECU? You can use Bosch or Martello dizzy’s. Get me the part numbers off of the injectors.
  3. Re: 97 Polo 16v (AFH) ECU reference?
    #53
    Jul 2018
    Funchal
    Hi [Crasher] ,sorry this is the right reference of the dizy fitted on the car 030905205AB if it was a original bosh part or the like would have the brand stamped on it am i right?
    Yes im still using the D ecu at the time i was looking for E version, used but couldnt find any local to me... (even over seas they seem hard to find)
    The reference at injectors was under the conector part of it and they all had this number:0306031A ,but at the back of them 2 had 2146 ,and each of the others had 2326 and 1036
    Chassis:WVWZZZ6NZVY143524
  4. Re: 97 Polo 16v (AFH) ECU reference?
    #54
    1841 Post(s)
    Remind me tomorrow.
  5. Re: 97 Polo 16v (AFH) ECU reference?
    #55
    Jul 2018
    Funchal
    Hey [Crasher] , good news the car passed emissions took for a long ride so i got to mot with it hot, maybe because acceleration on idle it doenst miss...
    Did you checked the injector´s reference?
  6. Re: 97 Polo 16v (AFH) ECU reference?
    #56
    Jul 2018
    Funchal
    If you remenber mate please check the injectors reference...
    Thank you
  7. Re: 97 Polo 16v (AFH) ECU reference?
    #57
    1841 Post(s)
    Remind me Monday
  8. Re: 97 Polo 16v (AFH) ECU reference?
    #58
    Jul 2018
    Funchal
    Sorry mate i forgot to check the fórum for replies...
    When you can check the reference.
  9. Re: 97 Polo 16v (AFH) ECU reference?
    #59
    1841 Post(s)
    The VW number is as you have, 036 906 031 A which is a Bosch type EV-14-EK, part number 0 280 158 229, it flow 137 grams of fuel per minute and has a resistance of 12Ohms.
    http://emea.resource.bosch.com/AA/in...000/index.html
  10. Re: 97 Polo 16v (AFH) ECU reference?
    #60
    Jul 2018
    Funchal
    Thank you very much Crasher, now i can rest my mind on that knowing they are the correct ones...
    Edit: mine only has 2 spray holes instead of 4...
  1. 97 Polo 6N1 (AFH) Throttle body reference?
    By B600power in forum Polo - Derby - Lupo - Fox
    Last Post: 27-07-2018, 11:33 AM
  2. 2005 alhambra reference tdi-help needed please
    By harty2000 in forum Alhambra
    Last Post: 16-07-2014, 07:33 PM
  3. VCDS Reference values
    By johnvw in forum VCDS - General Questions
    Last Post: 03-03-2011, 09:12 AM
  4. Audi A4 air con reference mode
    By bags in forum New Member Introductions
    Last Post: 13-11-2009, 10:25 PM
  5. A4 Air con reference mode
    By bags in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 13-11-2009, 07:30 PM
