Thread: Stop/Start -stopped working??
Results 1 to 10 of 11
  1. Stop/Start -stopped working??
    Feb 2014
    Northern Ireland
    6 Post(s)
    Wondered could someone help?
    I bought my A6 S line about 2 months ago and the Stop/Start activated all the time... I was getting frustrated by it so the first thing i did when started was turned it off using the switch on the dash. Now I've noticed it never activates.... even when i turn it back on?
    Anyone ever experienced this? Just want to make sure it still works ok, but i cant get my car to stop/start
  2. Re: Stop/Start -stopped working??
    Feb 2016
    Hungary
    113 Post(s)
    Quote Originally Posted by Baz_doc View Post
    Wondered could someone help]Now I've noticed it never activates.... even when i turn it back on?
    Be happy to not to use this bug... er, so called "feature". Honestly, the reason could be quite obvious, if you use the climate unit, it usually never turns off the engine, and on low battery power this systm never activates. It's also a normal behaviour not to activate if the engine's temperature is low.
    Audi Q7/4M MY2016, 3.0 TDI/200 KW Quattro
  3. Re: Stop/Start -stopped working??
    1836 Post(s)
    Your battery and starter will last longer... If the symbol on the dash has a line through it there could be a reason that will come up with a code read.
  4. Re: Stop/Start -stopped working??
    Feb 2014
    Northern Ireland
    6 Post(s)
    Thanks for the reply, yeah the symbol appears with a line through it... any idea how to find out what it is stopping this workin? Is there something on VCDS that would advise me?
  5. Re: Stop/Start -stopped working??
    Feb 2016
    Blaydon, North east England
    53 Post(s)
    Do you have 4 zone climate? If so check the temp setting in the rear, if its set really low or high then your stop start wont kick in. Think its the same if your in sport mode.
    2015 A6 Allroad 3.0TDi 218 CRTE - NEW
    2012 A6 Avant 3.0TDi Multitronic - OLD
  6. Re: Stop/Start -stopped working??
    Feb 2014
    Northern Ireland
    6 Post(s)
    Hi Kev,
    I don't have 4 zone climate.... yesterday I turned off my radio, lights, fan for air circulation etc and nothing plugged into the cigarette lighter and the symbol still appeared and start/stop would not work
  7. Re: Stop/Start -stopped working??
    Mar 2014
    Edinburgh
    235 Post(s)
    Do you have manual or auto ?
  8. Re: Stop/Start -stopped working??
    1836 Post(s)
    It could be that the battery is weak and the battery monitoring unit will pick this up so yes a full systems fault code scan first.
  9. Re: Stop/Start -stopped working??
    Feb 2014
    Northern Ireland
    6 Post(s)
    Its an Auto DSG... I will try a full auto-scan using VCDS and see if it brings anything up was hoping i was missing something simple
  10. Re: Stop/Start -stopped working??
    Feb 2016
    Hungary
    113 Post(s)
    I think the most easiest thing is to check the battery level
  1. Start/stop feature not working?
    By nilli in forum Q7 - 4M Forum - 2016 -
    Last Post: 10-11-2018, 10:30 PM
  2. Stop Start not working
    By nevbadger99 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 31-05-2018, 03:11 PM
  3. Question 'Popping' sound under dash when stopped using Start-Stop
    By patomlin76 in forum Audi A3 - 8V - 2012 - 2016
    Last Post: 16-08-2017, 08:13 PM
  4. Please Help Automatic Start\Stop not working
    By Splatman in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 17-10-2012, 07:27 PM
  5. Stop/Start not working?
    By breedop in forum Bluemotion
    Last Post: 10-06-2010, 08:55 PM
