Thread: Dual Mass Flywheel
Results 1 to 8 of 8
  1. Dual Mass Flywheel
    Nov 2005
    Towcester, UK
    I have just changed the clutch on my 2000 A6 2.8 Quattro and decided to change the flywheel as the old one appeared to have more play than I would have expected. When the new one arrived it also had play in it, so i concluded that this was normal and fitted it anyway on the basis that it was a good investment having taken gbox etc out. Now having got it all back together I am suprised to find more transmission shunt than I had before - and as I cannot find any loose mountings that I might have missed I am beginning to wonder if the flywheel is at fault!?
    On both the ones I have played with (i.e the old one coming out and the new one going in) there was an element of play between the two masses - or in other words you could turn the clutch mass 3-4mm at the outside rim whilst the engine mass stayed constant. It strikes me that this could cause shunt in the transmission particularly on overun for example as the slack is taken from on extreme to another when the engine comes of the power and effectively becomes a brake.
    Any thoughts?
    AndyH
  2. Re: Dual Mass Flywheel
    Sorry I can't help you but I am interested in how you did the change of clutch etc? i.e. how you got on with it, did you use a manual? etc
  3. Re: Dual Mass Flywheel
    Nov 2005
    Towcester, UK
    It is not an overly complicated job (if you have a spanner brain!) but there is a fair bit to do and a lot of it is very fiddly. I read the Audi workshop manual before I started so that I had an idea of what was what.
    Having said that I have access to a full workshop, a 2 post lift and hydraulic gearbox stands and on reflection I would not have really wanted to do it in the garage with just axle stands!
    Whole job took me a week on and off - but I expect it was 8 - 10 productive hours and I imagine it would take me less if I did it again - which given the first post I might well be doing!
    AndyH
  4. Re: Dual Mass Flywheel
    There is a chance that you can put it back to the old solid type on some
  5. Re: Dual Mass Flywheel
    Can I ask, where did you get the manual from?
  6. Re: Dual Mass Flywheel
    Hi i don't get what you er look for sorry
  7. Re: Dual Mass Flywheel
    Nov 2005
    Towcester, UK
    Quote Originally Posted by Niall76 View Post
    Bentley publishing in the US, but also got a copy of Elsawin (complete manual all vag cars) from ebay
    AndyH
  8. Re: Dual Mass Flywheel
    GOOGLE SEARCH for the manual.. ..some on ebay. cd format for ya p.c
    http://motors.listings.ebay.co.uk/Au...istingItemList
    just order the lot and sell them on here lol..Hope that helps
  1. Sharan dual mass flywheel
    By soup_dragon in forum Touran - Sharan - Caravelle
    Last Post: 05-07-2010, 05:07 PM
  2. Dual Mass Flywheel Fault?
    By TDiBoraSam in forum Bora - 1998 - 2005
    Last Post: 02-09-2007, 07:43 PM
  3. dual mass flywheel
    By jimbob in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 30-06-2007, 01:22 PM
  4. Dual Mass Flywheel
    By Richardm in forum Passat - Archive Topics
    Last Post: 27-03-2007, 02:54 PM
  5. How much should a new Dual Mass FLywheel cost?
    By kieranpage in forum Archive posts
    Last Post: 22-01-2007, 02:13 PM
