Thread: Audi A4 maf sensor error
  1. Audi A4 maf sensor error
    Sep 2018
    basingstoke uk
    hi i replaced the maf sensor on my audi. It now judders at idle with the revs fluctuatting by them selves if i unplug the sensor enginr ticks over smooth also when i switch the engine off i get the light symbol and the break warning light followed by the low oil presure light and a beeeeep. If i put the old one back in it all goes back to normal no problems. I have looked around but cant find anyone with all those errors just from changing the maf sensor. Thank you f you can help. On a side note which vag com cable do i need for a audi a4 140 2lt tdi B7 2007 convertible and is 39mpg uk miles normal for motorway driving.
  2. Re: Audi A4 maf sensor error
    1840 Post(s)
    You must buy a genuine VCDS cable, because of what you have done you will have to clear the codes you find (after saving them) and then drive it to see what comes back and go from there.
  1. Intake Air Temp. Sensor error - Audi A6 C6
    By k114l3d in forum VCDS - Help Requests
    Last Post: 29-04-2015, 08:16 PM
  2. DPF pressure sensor with error 2,250,0
    By cmsmith101 in forum Golf MK6 - 2009 - 2013
    Last Post: 06-07-2013, 08:33 PM
  3. Replies: 0
    Last Post: 09-09-2012, 10:42 PM
  4. p2201 nox sensor error
    By barcrawler in forum Golf MK5 - 2004 - 2009
    Last Post: 16-06-2009, 06:22 PM
  5. error 00519 map sensor g71 where is it
    By zorgman in forum Touran - Sharan - Caravelle
    Last Post: 19-03-2008, 08:46 PM
