Thread: Long drive after using fuel treatment, now got EPC light on
Results 1 to 10 of 12
  1. Long drive after using fuel treatment, now got EPC light on and oil in sparkplug hole
    Liverpool
    7 Post(s)
    Drove about 150 miles yesterday in the 3.0 V6 petrol Audi, and put a can of Cataclean in before we set off. Went like a dream. Returned to it last night to drive home, and it took ages to fire up. Turned over at full speed (not like a flat battery sound) but took 10 or 15 seconds to start, and didnt feel right on the journey home. Idle revs sat now sitting 1200rpm instead of the usual 800 ish.
    Going to scan it over the weekend when i can borrow a scanner, but any ideas please guys? Could the can of cleaner highlighted an issue?
    Used her today and now the engine management light is on as well.... help
  2. Re: Long drive after using fuel treatment, now got EPC light on
    scotland
    34 Post(s)
    Quote Originally Posted by glenbat View Post
    Check the pcv valve, they usually break and stick open, resulting in high idle, lumpy running. It basically upsets the fuelling, I think the cataclean is unrelated.
    Sent from my ANE-LX1 using Tapatalk
  3. Re: Long drive after using fuel treatment, now got EPC light on
    Liverpool
    7 Post(s)
    Quote Originally Posted by calum View Post
    Thanks Calum, sorry, whats the pcv valve and how would you check it?
    Also, drove it to work this morning and the EPC light no longer on, but the engine management light is still on. Car seems to be starting better again too, not sure if related or not?
  4. Re: Long drive after using fuel treatment, now got EPC light on
    18 Post(s)
    414 Post(s)
    Try taking the oil cap off with the engine running. Cataclean has been known to melt cats, does it pink when you accelerate?
    Dark was that day when Diesel conceived his grim engine that begot you, vile invention, more vicious, more criminal than the camera even, metallic monstrosity, bale and bane of our culture, chief woe of our Commonweal. How dare the Law prohibit hashish and heroin yet license your use, who inflate all weak inferior egos? Their addicts only do harm to their own lives: you poison the lungs of the innocent, your din dithers the peaceful, and on choked roads hundreds must daily die by chance-medley. Nimble technicians, surely you should hang your heads in shame. Your wit works mighty wonders, has landed men on the Moon, replaced brains by computers, and can smithy a "smart" bomb. It is a crying scandal that you cannot take the time or be bothered to build us, what sanity knows we need, an odorless and noiseless staid little electric brougham.
    W.H. Auden (1907-1973), A Curse:
  5. Re: Long drive after using fuel treatment, now got EPC light on
    Liverpool
    7 Post(s)
    Thanks Crasher, took the oil cap off while it was running and you could hear the vacuum change and compensate for the cap being off.
    Had no idea about the cataclean, I'll avoid it in the future. Will let you know about pinking when i use it in the morning. i managed to get it scanned tonight and came up with:
    16805 Warm up catalyst Bank 1 Efficiency Below Threshold P0421 Upper Limit Reached
    16706 Engine RPM Sensor - G28 No Signal P0322 No Signal/No Communication
    17772 Cylinder 4 Ignition Circuit Open Circuit P1364 No Signal/No Communication - Intermittent
  6. Re: Long drive after using fuel treatment, now got EPC light on
    18 Post(s)
    414 Post(s)
    So it did not try to rip the oil cap out of your hand and it looks like the right hand cat is not happy, it could be burnt out due to an ignition problem but that says bank 2 not bank 1.
    1 1 0
  7. Re: Long drive after using fuel treatment, now got EPC light on
    Liverpool
    7 Post(s)
    It did try to suck the cap back into the hole, yep. Guess that means thats working as it should?
    I swapped coil pack 4 for a spare i had indoors (because of the 17772 code) and it was fine for a few days, but today its a bit lumpy again. No warning lights on dash though. I did notice a little oil in spark plug 4 hole, so cleaned it out best i could, unsure if it comes from the mrs being a bit messy when topping her up with oil (there was a little in the rocker cover securing bolt recess nearest the oil filler too), or could it of comeup from the sparkplug hole itself??
  8. Re: Long drive after using fuel treatment, now got EPC light on
    18 Post(s)
    414 Post(s)
    The cap should not have much suction behind it, just a gentle pull. If it is a high vacuum it means the crank case breather has failed.
  9. Re: Long drive after using fuel treatment, now got EPC light on
    Liverpool
    7 Post(s)
    Thanks again, was more of a gentle pull as the cap was 1/2" from being located fully, certainly didnt require any effort to keep it out the fill hole
    What do you think about the oil in sparkplug hole 4 (front pass side)? New rocker cover gasket?
  10. Re: Long drive after using fuel treatment, now got EPC light on
    18 Post(s)
    414 Post(s)
    Yes, common problem. I did a service on something VAG (been to bed since) a few weeks ago and I had to use the vac pump to drain the plug bores and then blow the holes out with an air line and brake cleaner before I could take the plugs out.
  1. First long run, how shall I drive it?
    By Timbo in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 26-04-2014, 12:30 PM
  2. Diesel Fuel Treatment/Reduced Fuel Consumption
    By gould01 in forum Audi A5 - B8 Forum - 2007 - 2016
    Last Post: 15-01-2012, 05:38 PM
  3. Any good? Millers Oils Diesel Power Ecomax fuel treatment?
    By vishuk in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 14-12-2011, 10:26 AM
  4. Long Drive
    By stevemr in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 30-08-2010, 10:52 AM
  5. Powermaxx fuel system treatment
    By Beano21945 in forum Golf MK4 - 1999 - 2004
    Last Post: 17-09-2008, 02:03 PM
