Thread: Change units from Miles to KM
  1. Question Change units from Miles to KM
    Jan 2010
    BKara Malta
    Hi, I have a Mk7.5 e-Golf with Active Info Display. It was originally in miles. Through the vehicle settings, I changed the units to KM, but I ended up with the speedo showing MPH on the dial and KM/H at the bottom (see red boxes in photo).
    Is there any way that this can be changed for both to show KM/H please (using tools like VCDS or OBD-Eleven)?
    Thanks for your help
    Dave Malta
    Volkswagen e-Golf Mk7.5 2018
    Past :: VW Golf GTI Mk7 >> VW Golf 2.0TDI Mk6 >> VW Golf GT 2.0TDI Mk5
  2. Re: Change units from Miles to KM
    Aug 2019
    Warwickshire
    I've just run into the same issue with my 2018 Passat. I also assumed that changing the units would change the dial to kph, and not just provide an inset digital kph display. I checked with a technician at the VW dealer and he confirmed that there's no way to do this, not even he could do it with their equipment.
    I find this a weird backward step, potentially dangerous. If I glance at the speedo I might be momentarily confused by the conflicting info I see - dial in mph, digital readout in kph. I've yet to drive on the continent in this car so experience may show I'm wrong. All other cars I've ever had have dual markings on the speedo - you'd think with all the functionality available in the Active Info Display they'd be able to flip between the two. Makes no sense.
    And then it occurred to me, could this be deliberate - to discourage UK models to be sold on the continent, and vice versa? I bet deep down there is the ability to do this, it's just hidden. Would VW really go to the expense of producing different products for the separate markets when they could produce one? I don't think so.
  3. Re: Change units from Miles to KM
    Jan 2010
    BKara Malta
    Quote Originally Posted by deputiser View Post
    Hey, good morning. There is an easy way to do it. OBD11 - log in, go to the cluster settings, and change from mph to km/h (or vice versa). The gauge would be in whichever units you select, while the digit at the bottom would switch to the units of choice that you choose from the infotainment system. In my case, I left them both km/h. It's a 2 minute job.
    Hope that helps.
    Dave Malta
  4. Re: Change units from Miles to KM
    Aug 2019
    Warwickshire
    Thanks for that, I thought it must be possible. Sounds like the guy at the VW dealer was either not telling the truth, or plain ignorant.
    I called my local Audi/VW specialist (used to look after my previous Audi) to see if they could do this for me. They could - at a price - but did point out that any changes like this leave a footprint, and as the car is still under warranty, perhaps I'll wait until it isn't.
  5. Re: Change units from Miles to KM
    Jan 2010
    BKara Malta
    Welcome. I did it on mine (it's still under warranty). However, this is just a setting and shouldn't void the warranty.
    Dave Malta
  1. Question Allroad C5 2001 2.5 TDI headlamp change for S6 C5 units
    By 70chips in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 29-11-2017, 08:03 PM
  2. Audi A6 c6 km to miles change help needed.
    By turpal in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 08-10-2013, 08:31 PM
  3. Question Timing belt change at 32k miles?
    By Johnny21 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 10-09-2013, 09:03 PM
  4. Gearbox Change at 18,000 miles
    By lozzermo in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 30-01-2011, 07:11 PM
  5. change miles to kms
    By paulbarretts in forum Touran - Sharan - Caravelle
    Last Post: 08-02-2009, 12:09 AM
