Thread: 2002 2L petrol model Clutch 'stuck'
Results 1 to 8 of 8
  1. 2002 2L petrol model Clutch 'stuck'
    Mar 2009
    Newton Swansea
    This Alhambra has been off the road for a couple of years I've been doing a few jobs on it odd bits of rust & general tidy up 180,000 miles on the clock still 'starts on the button' (yes I know it's a key start!) but now I can't engage gears as the clutch won't release. Difficult to test if slave or master cylinder is working as it is a concentric unit inside the bell housing (any ideas of how to test) Alternative is plate stuck to flywheel by rust it has resisted all attempts to free it so far. That includes wedging the pedal down for a few weeks no luck. Having read the manual it is a nightmare job for DIY so I guess it is a Garage Job just looks expensive, special tools etc.I've got a bit more welding & a replacement Brake front disc to do. then it will be ready for MOT. Any thoughts have I missed something?
  2. Re: 2002 2L petrol model Clutch 'stuck'
    Aug 2018
    Gloucester UK
    7 Post(s)
    I had a similar problem with my Hillman Minx many years ago as I was away at work a lot. I used to jack up one drive wheel and start it in gear so the wheel was spinning. I then jabbed the brake and it unstuck. This may be dangerous though !!!!
  3. Re: 2002 2L petrol model Clutch 'stuck'
    1835 Post(s)
    If the pedal returns the release bearing and the pressure plate is working so the friction plate would be stuck to either the flywheel or pressure plate, box out and new clutch, flywheel and release bearing.
  4. Re: 2002 2L petrol model Clutch 'stuck'
    Mar 2009
    Newton Swansea
    Yes the pedal 'feels' similar to my other Alhambra & returns OK so I think you are right. It will be time to 'bite the bullet'! I must just finish the welding & fit the other Front disc. Thanks for the advice Crasher.
  5. Re: 2002 2L petrol model Clutch 'stuck'
    Mar 2009
    Newton Swansea
    Quote Originally Posted by KeithOT View Post
    Does this model have a dual mass flywheel it is not a diesel but 'Car Parts 4 You' website says it has?
  6. Re: 2002 2L petrol model Clutch 'stuck'
    1835 Post(s)
    Yes it has a DMF.
  7. Re: 2002 2L petrol model Clutch 'stuck'
    Mar 2009
    Newton Swansea
    Yes it has a DMF.
    Oh OK you live & learn!Thanks!
  8. Re: 2002 2L petrol model Clutch 'stuck'
    1835 Post(s)
    I don’t mind too much deleting the DMF on a petrol engine, I am building a Golf 2 with. VR6 and I have converted it to the same 02M box and have used a Sachs Sporting single mass but I know it will make the gearbox chatter at idle.
  1. Petrol cap locking bolt - stuck!
    By Jem1 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 16-09-2009, 08:33 PM
  2. 99 Polo petrol cap stuck, central locking broke
    By vwhoch in forum Polo - Derby - Lupo - Fox
    Last Post: 24-08-2009, 01:07 AM
  3. VW Tdi 1.9 2002 model
    By tkblueyonder in forum Golf MK4 - 1999 - 2004
    Last Post: 17-08-2008, 09:23 AM
  4. PETROL FLAP STUCK **urgent**
    By alanscottgraham in forum Beetle 2000-
    Last Post: 04-02-2008, 10:05 PM
  5. Clutch is stuck Audi A3 97 model
    By Maz in forum Audi A3 - Archive Topics
    Last Post: 04-09-2007, 08:21 PM
