Thread: VW Crafter heater control please help
  1. VW Crafter heater control please help
    Sep 2018
    Norfolk
    Hi I have a 2011 Vw crafter with air conditioning and the control panel has died, ive checked the following
    fuses ok
    fan motor works fine when powerd with 12v
    resister changed
    changed the switch panel with a used one from a breakers but was from a sprinter i just went by the pictures because its the same as original.
    im at a dead end with it, does the control panel/switches on a used part have to be identical part numbers a new unit is over £800 and id rather put in a used one if i can.
    thanks
  2. Re: VW Crafter heater control please help
    Aberdeen
    63 Post(s)
    Welcome to the forum. I have moved this to the correct section. Have you had the van read for faults?
  1. crafter cruise control retro-fit
    By blade883 in forum The Commercial Range
    Last Post: 19-04-2018, 07:38 PM
  2. Crafter 2.5 cruise control activation help
    By Rab025 in forum The Commercial Range
    Last Post: 28-11-2016, 10:48 PM
  3. Please Help Crafter CR35 radio volume control not working
    By Adethefade in forum The Commercial Range
    Last Post: 04-06-2015, 02:20 PM
  4. T4 Heater control
    By Harley1998 in forum The Commercial Range
    Last Post: 05-04-2009, 03:44 AM
  5. Heater control
    By 80quattro1987 in forum 80 - 90
    Last Post: 12-12-2007, 05:15 PM
