Thread: Advanced (Direct) Tyre Pressure Monitoring System - Retrofit
Results 21 to 30 of 38
  1. Re: Advanced (Direct) Tyre Pressure Monitoring System - Retrofit
    #21
    Feb 2019
    MIDDLESBROUGH UK
    26 Post(s)
    Hi Andy,
    I am giving this mod a go , all hardware installed fairly simple.
    Iv'e sent youn a PM with a query.
    Keith
  2. Re: Advanced (Direct) Tyre Pressure Monitoring System - Retrofit
    #22
    Jun 2016
    Edinburgh, UK
    11 Post(s)
    Keith
    I have been looking at this with Andy's help - but haven't yet cranked the car open to do the retrofit. How easy was the wiring? Especially the CAN lines?
    Jonathan
  3. Re: Advanced (Direct) Tyre Pressure Monitoring System - Retrofit
    #23
    Feb 2019
    MIDDLESBROUGH UK
    26 Post(s)
    Hi Jonathan,
    Wiring was fairly straightforward,
    12v , Gnd, two Can wires.
    I have the 360 camera module installed in the boot just below the fuse board,
    luckly the Can wires are there and I just spliced into these.
    If you only have the backup camera the wires are with that.
    Not sure wherelse you can pick them up I'll check the wiring diagrams.
    Good luck
    Keith
  4. Re: Advanced (Direct) Tyre Pressure Monitoring System - Retrofit
    #24
    Feb 2019
    MIDDLESBROUGH UK
    26 Post(s)
    Just had a quick look, If no cameras pretty sure you will have the AddBlue
    unit in the boot so you could pick them up there .
    The offending wires were -( twisted pair ) orange/grey and orange/brown.
    Hope this helps .
    Keith
  5. Advanced (Direct) Tyre Pressure Monitoring System - Retrofit
    #25
    Nov 2015
    U.K.
    78 Post(s)
    If it is any consolation to those less adventurous than this, I proved the standard indirect TPMS works OK yesterday. Nail in rear right on A1M. No spare tyre as that’s where the BOSE subwoofer is :-). Warning kicked in when the pressure (measured shortly after I stopped) got to under 30 psi. Luckily after a short low loader trip, a local dealer had some of the stock AO Pirelli’s in...
    | Q7 3.0 TDi ABT Power 325bhp MY16 S-Line Tech/Tour/Trailer packs, orca black, 21 inch 9.5J rims, rotor grey leather, sunroof, BOSE, ambient lighting, reversing cam, drivers memory seat. Gtechniq Crystal Serum Ultra ceramic coating |
  6. Re: Advanced (Direct) Tyre Pressure Monitoring System - Retrofit
    #26
    Oct 2017
    Singapore
    Hi Andy,
    I have just retrofitted TPMS but i only can use the sport display option in order to display the TPMS in VC. Not sure yours is the same. I have made changes to 17 under TPMS-BAP and enabled it. Can you share your coding so i can check? Thanks.
  7. Re: Advanced (Direct) Tyre Pressure Monitoring System - Retrofit
    #27
    Mar 2010
    37 Post(s)
    228 Post(s)
    Quote Originally Posted by sbc55 View Post
    Hi Andy,
    Yep. That's how you view it on the VC. Under sports display. You've done the right way.
    Good Job
    Andy
  8. Re: Advanced (Direct) Tyre Pressure Monitoring System - Retrofit
    #28
    May 2010
    Singapore
    Hi, do you happen to have a photo of this location? Is the 360cam Module below the subwoofer or Bose module?
  9. Re: Advanced (Direct) Tyre Pressure Monitoring System - Retrofit
    #29
    Feb 2019
    MIDDLESBROUGH UK
    26 Post(s)
    The camera module is mounted to the left of the bose module.
    Under the fuse board. stood on end with lots of coloured plugs!
    keith
  10. Re: Advanced (Direct) Tyre Pressure Monitoring System - Retrofit
    #30
    May 2010
    Singapore
    Quote Originally Posted by mazerati View Post
    keith
    Thanks for the information.
  1. Tyre Pressure Monitoring System
    By D4D in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 18-02-2013, 09:16 AM
  2. Please Help Tyre pressure monitoring system TPMS issue
    By wmccann in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-10-2012, 01:18 AM
  3. Retrofit Tyre Pressure Monitoring
    By GeoffW in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 22-08-2011, 10:18 AM
  4. Tyre Pressure Monitoring System (TPMS)?
    By Bratty in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 22-08-2010, 10:19 AM
  5. Tyre pressure monitoring system & new wheels
    By rfmacaskill in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 03-05-2010, 01:59 PM
