Thread: Brake pad wear light symbol and abs module unit
  1. Brake pad wear light symbol and abs module unit
    Sep 2018
    Shrewsbury
    I've a A3 2006 2ltr fsi. When I bought the car a yr go the front brake calipers and pads had been renewed. The sensor wasn't connected up but shorted out to prevent the the brake pad wear light from showing on dash. For my mot I've had to replace the rear brake pads and one of the small metal pipes, obviously bleeding the system through. Brakes work fine now all round. However the brake pad wear symbol is still on the dash so they won't pass the mot, very frustrating! I've checked all wiring and everything looks good to me. I bought a vagcom diagnostic tool to see if I could reset the codes and if anything else showed up. The only fault that comes up is 01316 which points towards the ABS module unit. Could this be my problem?, do they use the same warning light? Since doing my brakes aswell the ESP warning light won't go out, are they all linked to the same problem?
    any sensible advice would be appreciated as it's driving me crazy and to be honest I'm finding it unreasonable that it should fail the mot because the light is still on the dash.
    Cheers Andy
  2. Re: Brake pad wear light symbol and abs module unit
    Jul 2010
    Bradford, West Yorkshire
    could you post the vcds autoscan please
  1. Please Help Brake pad wear light on
    By lpm150689 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 21-03-2012, 02:36 AM
  2. Question Brake pad wear warning light:
    By mscnoe in forum Alhambra
    Last Post: 04-02-2012, 01:44 AM
  3. Please Help Polo brake wear warning light
    By Steven Wass in forum Polo - Derby - Lupo - Fox
    Last Post: 30-04-2011, 07:40 PM
  4. A6 brake pad wear sensor light on
    By grasshopper in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 23-06-2008, 11:38 PM
  5. brake pad wear warning symbol.
    By graham toogood in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 14-11-2007, 05:36 PM
