Thread: CBA Engine
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
  1. Re: CBA Engine
    1841 Post(s)
    I personally had one on a well cared for customers car and know off other instances; where the 2L CR has snapped its crank and cracked the block doing so but so far that is the only internal failure I know of, cam belt tensioner failure is rearing it’s ugly head again, are people neglecting to change the stud or using kits without it?
  2. Re: CBA Engine
    Oct 2017
    Halifax, West Yorkshire
    22 Post(s)
    I guess when people purchase the kit they expect all they need to change to already be there. Also what is it about Skoda's that makes them so reliable? I know by the time they get the tech from VW it's refined but they still use VW engines, parts etc
  3. Re: CBA Engine
    Sep 2018
    Thanks guys... Bit off topic but any opinions on the 1.6 TDI in a 2012 Skoda Yeti?’
  4. Re: CBA Engine
    1841 Post(s)
    The CAYC engine itself seems strong apart from a couple where we have seen oil pressure problems on very high mileage taxi's, one was the drive belt (yes it is Belt In Oil or BIO as it is known) and one was a badly worn crank due to huge miles and no oil changes. What IS a problem are the ancillaries, DMF's rattle as usual, DPF's block as usual, injectors fail and are £2.5K a set fitted, turbo actuator diaphragm failure is common, the EGR valves are a joke, we did two last week whilst I was on holiday and the high pressure fuel pump is VERY sensitive to running dry which is is nearly £2k job as they are timing belt driven, they fill the system with metal fillings which take some cleaning out and the pump is £1328.26 EXCHANGE! Add to this the emissions recall fiasco making them run like a sick pig and it makes it an engine that is great for the garage industry and crap for the owner!
  1. Replies: 3
    Last Post: 10-05-2012, 04:14 AM
  2. Replies: 6
    Last Post: 05-09-2011, 02:14 AM
  3. Question Replace injector loom in 2002 Golf TDi -ATD Engine Code - PD Engine ?
    By Negger in forum Golf MK4 - 1999 - 2004
    Last Post: 03-06-2011, 11:26 AM
  4. Question Knocking sound (inconsistant) on acceleration from engine (1995 Audi Coupe 2.0E - ABK engine)
    By Jonnovision in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 07-11-2010, 07:51 AM
  5. Question Engine problem - Engine speed sticks high / Unstable engine speed
    By sef-75 in forum Bora - 1998 - 2005
    Last Post: 29-09-2009, 09:52 PM
