Thread: Faulty fuel tank sender and how do I find the part number
  1. Faulty fuel tank sender and how do I find the part number
    Feb 2016
    London
    13 Post(s)
    My fuel gauge stopped working a few weeks ago - needle dropped to empty and DTE went to zero. Warning on the dash said 'Tank system malfunction! - contact workshop' I booked it in with Audi but then found it's not on my named component warranty cover so will fix it myself. Today I pulled out the rear seat base and opened the cover and after undoing reconnecting the electrical connections a few times didn't work I tapped the top of the unit with a spanner and the gauge jumped back into life! This is unlikely to be a permanent fix but at least it's isolated it to the drivers side and the unit and not the wiring. So how do I get hold of a part number for a new one? - are there any parts data files around or do I have to go to an Audi parts dept?
    2011 A6 Allroad 3.0TDI
  2. Faulty fuel tank sender and how do I find the part number
    Dec 2012
    Aylesbury
    I had a similar problem on mine. The fuel tank gauge would just drop to zero every now and again and a decent bash on the drivers side sender would spring it back to life for a random amount of time sometimes days, sometimes weeks. However it got a bit frequent so all you need to do is replace the inline wiring connections in the fuel tank - both sides if it’s a Quattro. there’s a kit 4F0 298 200 B which I used but just 6 scotch blocks will do the same job.
    Not a particularly nice job - but mines been fine ever since. Definitely cheaper than replacing the whole unit.
    2017 Audi S4 Navarra Blue
  3. Re: Faulty fuel tank sender and how do I find the part number
    Feb 2016
    London
    13 Post(s)
    That's great advice!
  1. cant find fuel tank sender 2003 A6 C5 Avant 1.9 Tdi
    By corrado999 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 03-03-2015, 09:18 PM
  2. Please Help Fuel pump/sender part number needed
    By starryeyes in forum Golf MK3 - 1993 - 1999
    Last Post: 14-02-2011, 10:01 AM
  3. Sharan fuel tank sender
    By 1958steveflying in forum Touran - Sharan - Caravelle
    Last Post: 22-12-2010, 12:52 PM
  4. Tdi fuel tank sender unit
    By shaun tdi in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 21-09-2009, 09:50 PM
  5. Replies: 2
    Last Post: 22-09-2008, 08:47 AM
