Thread: Audi A1 electrical gremlins cropping up, comfort module?
  1. Audi A1 electrical gremlins cropping up, comfort module?
    Apr 2012
    United Kingdom
    hi all. Got an A1 on a 60 plate, 1.6tdi. It has developed a few faults over the last couple of months and I was wondering if anybody could shed any light?
    The wipers froze completely, I removed the linkage and motor (pita) and applied 12v directly, it seemed to work fine, so I refitted it, and now it works, just not on full speed. However, it works on full speed off the car.
    Also, having the same sort of issue with the horn. It will stop working, take it off and apply 12v and it works fine, refit and it again works, but maybe only for a couple of weeks.
    Next one of the back lights intermittently works
    I was wondering if they maybe share an earth, or perhaps are all running off a faulty comfort control module as the car presumably runs a CANbus.
    On a seperate note. When it idles, it jumpseverywhere (when cold) it used to do it when warm, but then went to the dealers to have the emissions update, and now does it when cold.
    Audi have tried to remedy this shaking by fitting 4new injectors, and also an EGR valve, to no avail.
    Many thanks!
  2. Re: Audi A1 electrical gremlins cropping up, comfort module?
    Apr 2012
    United Kingdom
    Horn seems to be working after changing it for a new one. No faults on VCDS. wiper motor changed to no avail. Discovered it loses its earth on pin 2 as soon as you switch it to full speed. If you manually give it an Earth it works fine?
  1. audi a4 (b6)comfort control module location
    By jayjayjay12 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 04-08-2014, 11:48 AM
  2. Opening Audi Comfort Module without breaking it!
    By Dean Mancell in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-09-2012, 11:12 PM
  3. Audi a6 avant tdi - electrical gremlins
    By Haggag01 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 03-03-2010, 11:50 AM
  4. audi electrical gremlins
    By rev-ian in forum New Member Introductions - Sponsored by BVR Automotive
    Last Post: 29-09-2008, 10:20 PM
  5. Audi A6 Comfort Module Repair Petition
    By Arnot in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 24-03-2008, 01:50 PM
