Hi all,
AC blows cold on both side but heat only comes out of the passenger side vents....the same for the back vents as well. I had the same issue on a Jeep Grand Cherokee and found the spindle that the flaps (blend doors) had sheared off so i replaced it and got it working so i suspect either the same things has happended on the Touareg or the motor has failed but either way how do i get to motor/flaps on a Touareg 2006 ?
FYI
3 Faults Found:
01810 - Actuating Motor for Temperature Flap; Right (V159)
000 - -
00710 - Defroster Flap Positioning Motor (V107)
000 - -
01592 - Air Quality Sensor (G238)
014 - Defective
