Thread: help with VCDS codes please!
  1. help with VCDS codes please!
    May 2017
    Middlesbrough
    Guys My cars runs fine but the VCDS has generated the following codes - can anyone help me work out what it means - do I need to be worried / do anything with the engine?
    Chassis Type: 4B (4B - Audi A6/S6/RS6/allroad C5 (1998 > 2005))Scan: 01 02 03 06 08 15 16 17 18 22 34 35 36 37 45 55 56 57 65 67
    75 76 77
    VIN: WAUZZZ4B53N114433
    Address 01: Engine Labels: 059-907-401-AKE.clb
    Part No: 4Z7 907 401 B
    Component: 2.5l/4VTEDC G000SG D09
    Coding: 01015
    Shop #: WSC 02325
    VCID: 3C2137E14F7BA8D76DC-4B3D
    Subsystem 1 - Part No: 00018059
    Component: 130 106EC150_1.R75314164384
    WAUZZZ4B53N114433 AUZ7Z0C2405346
    5 Faults Found:
    01375 - Valves for Engine Mounting; Stage 1
    38-10 - Output won't Switch or Short to Plus - Intermittent
    01318 - Control Module for Injection Pump (J399)
    49-00 - No Communications
    01686 - Control Module for Cooling-Fan After-Run (J138)
    31-00 - Open or Short to Ground
    01265 - Exhaust Gas Recirculation Valve (N18)
    01282 - Intake Manifold Flap change-over Valve (N239)
    Readiness: N/A
    The air con has never worked so its no surprise its generated these too - can anyone help me identify whats to do? Theres a leak somewhere suspected condenser that I already know about but is there something else?
    Address 08: Auto HVAC Labels: 4B0-820-043-MY2.lbl
    Part No: 4B0 820 043 AC
    Component: A6-Klimavollautomat 0105
    Coding: 00004
    Shop #: WSC 02325
    VCID: 5BE3947DAA058FEF446-258F
    3 Faults Found:
    01810 - Actuating Motor for Temperature Flap; Right (V159)
    41-10 - Blocked or No Voltage - Intermittent
    00819 - High Pressure Sensor (G65)
    07-00 - Signal too Low
    01317 - Control Module in Instrument Cluster (J285)
    49-10 - No Communications - Intermittent
    cheers
    Mark
    '18 A3 tron (co.car) | '15 A4 2.0TDI ultra (Mrs) | 53 2.5TDI Allroad (project) | '84 205GTI (toy)
  2. Re: help with VCDS codes please!
    Aug 2018
    uk
    You could have a look at Ross-Tech web site and look up the fault codes you have-the info will be there !! Sorry I not much help !!
  3. Re: help with VCDS codes please!
    Aug 2018
    uk
    Just a thought, as your car runs ok, have you cleared the code you have and see if they return ???? on basis that car is runnung ok asis !!
  4. Re: help with VCDS codes please!
    May 2017
    Middlesbrough
    Quote Originally Posted by A55 View Post
    Thanks Ill try that! but good point to reset codes as they maybe historic.
    cheers A55
  5. Re: help with VCDS codes please!
    Aug 2018
    uk
    How did you get on after clearing the codes ?? is all ok or did you get some or all back ???
  1. Please Help VCDS Fault Codes
    By paulb34 in forum VCDS - Help Requests
    Last Post: 07-04-2018, 11:51 AM
  2. VCDS codes And logs help
    By golfmk4ATD in forum VCDS - Help Requests
    Last Post: 23-05-2014, 10:46 AM
  3. vcds and (V5) different engine codes, why??
    Last Post: 22-05-2014, 10:18 AM
  4. VCDS error codes
    By szladob in forum VCDS - General Questions
    Last Post: 05-04-2014, 11:09 PM
  5. help with vcds fault codes
    By chrismk5 in forum VCDS - Help Requests
    Last Post: 15-06-2012, 05:43 PM
