Thread: Fault code P2563 Turbocharger Boost Control Position Sensor Circuit: Implausible Signal
  1. Fault code P2563 Turbocharger Boost Control Position Sensor Circuit: Implausible Signal
    Aug 2018
    Kent
    Hello guys
    Iím after for some help with my Audi A3 2.0 TDI 170 2010
    My coil light is flashing and seems to be happening more regularly now which I guess is a good thing as maybe able narrow the fault down if itís on all the time.
    Iíve scanned the car and it is showing a fault code P2563
    I know these are the possible problems
    Wiring and/or Connections from/to Vane Position Sensor (G581) faulty
    Engine Control Module (ECM) faulty
    Binding Issues due to Adjustment/Turbocharger
    Excessive Carbon build-up
    Vacuum Leak from/to Turbocharger (Wastegate) Actuator and Solenoid Valve for Boost Pressure Control (N75)
    The car drives fine no loss of power no limp mode
    Iíve read our posts on other forms no one seems to come up with an answer which is why I thought I would start my own post and hopefully finding a solution
    Lucky enough I have a 2007 Audi A3 170 so I can swap around sensors for testing.
    Iíve swapped the boost pressure converter sensor still the same I havenít tried swapping any of the N75 sensors yet.
    Iíve checked all the houses and havenít seen any kinks or splits.
    I have a feeling there is the sensor on the actuator can this be tested?????
    Iíve seen people mentioning using VCDS and on the measuring blocks using 034.2 34.3????
    My VCDS measuring blocks donít seem to bring up the decimal point I only seem to get 034.
    Basically what Iím asking is has anybody had fault code P2563 and actually managed to fix it and what did they do
    Thanks for your advice and help
  2. Re: Fault code P2563 Turbocharger Boost Control Position Sensor Circuit: Implausible Signal
    Aberdeen
    30 Post(s)
    I have moved your thread so you will hopefully get an answer.
    You could also try the ross tech site for ideas. http://wiki.ross-tech.com/wiki/index...5/P2563/009571
    Current- S3 Sportback Nav S-tronic, Mythos Black, B & O, Comfort Pack, Lumbar Support, Lunar Silver interior.
    Gone-A6 C7 biturbo saloon, A6 C6 3.0 tdi Quattro saloon, A6 C5 2.8 Q Avant
  1. Please Help 58 plate Passat clutch position sensor implausible signal problem
    By Thomas2309 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 28-10-2018, 07:58 PM
  2. Replies: 0
    Last Post: 26-04-2018, 11:45 AM
  3. Replies: 0
    Last Post: 10-03-2017, 10:58 PM
  4. A3 won't start fault code 01176 - key - 008 - implausible signal - intermittent
    By dontclickonthis in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 03-09-2016, 03:10 PM
