Thread: 04 Allroad front control arm easy replacement?
  1. 04 Allroad front control arm easy replacement?
    May 2017
    Middlesbrough
    Guys, Ive got a load of play in the bushes of the front control arm (and a vibration at speed) so Im going to change the front control arms - can anyone tell me is it an easy job and do I need to jack up car and wheel etc?
    cheers
    (Im going feb at £50 each from FEBI BILSTEIN Track Control Arm Front Axle Right (33363) buy cheap online)
    '18 A3 tron (co.car) | '15 A4 2.0TDI ultra (Mrs) | 53 2.5TDI Allroad (project) | '84 205GTI (toy)
  2. Re: 04 Allroad front control arm easy replacement?
    1835 Post(s)
    Audi call those wishbone links and for the Allroad they are specific and not used on anything else or available aftermarket as far as I can tell without being at work to double check, Audi part numbers 4Z7 407 693 D and 694 D left and right respectively and these are £212.04 each. The damper link (AKA control arm) is also type 4BH specific.
  3. Re: 04 Allroad front control arm easy replacement?
    May 2017
    Middlesbrough
    cheers Crasher, the link looks like the one I need though and its febi which ive been told are the ones to get?
  4. Re: 04 Allroad front control arm easy replacement?
    Jan 2015
    Israel Kfar uriya
    9 Post(s)
    Quote Originally Posted by 03Allroad View Post
    cheers
    If it is only the rubber bushing it can be replaced, much cheaper. Internal 4D0407182G external 4D0407181H. Another thing, after you have installed the control arm, you need to tighten the screws when the center of the wheel is 402 millimeters from the wing of the vehicle.
  5. Re: 04 Allroad front control arm easy replacement?
    May 2017
    Middlesbrough
    Quote Originally Posted by amiram View Post
    Cheers Amiram, yes i did see those, i dont have a press though so not sure how successful Ill be at getting it out with a socket and hammer?!
    Thanks for the reminder about torquing it up I had read that someone else too, make sense to stop it twisting when under load.
  1. Replacement Blue Arm & Clip for Front Right Allroad C5 Level Sensor
    By ceilidhalfie in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 20-01-2018, 10:06 PM
  2. Please Help Help *** Front lower curved control arm replacement
    By wmccann in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-08-2017, 01:40 PM
  3. Question 2001 2.5TDI Allroad Front lower forward Control arm
    By 70chips in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 06-01-2016, 10:12 AM
  4. allroad front upper control arm angles
    By ben0069 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 08-02-2013, 03:43 PM
  5. Help please with allroad acoustic parking control unit replacement
    By garyizme in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 08-01-2013, 06:37 PM
