Thread: Cold misfire cyl #1
  1. Cold misfire cyl #1
    Aug 2018
    EU
    Greets
    I've been having some trouble with my tdi pd150.
    On cold starts I get misfires for the first 5 seconds, with white smoke, and injector #1 reading starting at 2.99, and slowly droping, 10 secs after the engine is fine, the other injectors are ok, just negative compensating the first injector,
    When warm I get all the injectores between -0.12 and 0.12, due to new camshaft and lifters. While warm is perfect. Pulls ok, mpg is ok.
    Oil level doesnt move.
    Have clear lines at the fuel filter, no oil on fuel.
    I have a video with inj values but I can't share it. I'll give you the numbers since the engine is turned on, after sitting for +8 hours at 17°C, the values appear every second since startup, from 1 to 4 cyl has vcds shows:
    2.99 -1.41 -1.15 -0.59
    2.99 -1.29 -1.29 -0.52
    2.99 -1.27 -1.36 -0.47
    2.96 -1.18 -1.41 -0.40
    2.80 -1.08 -1.46 -0.21
    2.61 -1.04 -1.48 -0.07
    2.40 -0.94 -1.44 0.00
    2.16 -0.87 -1.36 0.02
    1.93 -0.80 -1.29 0.09
    And after some minutes:
    -0.02 -0.12 0.00 0.12
    On a compression test, cold readings, I get:
    #1 28.5bar
    #2 33bar
    #3 30bar
    #4 32bar
    #1 27bar
    Hot:
    #1 29bar
    #2 33bar
    #3 31bar
    #4 32bar
    #1 30bar
    Yesterday I swap Injector #1 and #2 to check if the inj deviation moves, also swapped the wiring loom.
    Today, 20°C, I start the day with these values:
    2.61 -1.20 -1.01 -0.38
    2.64 -1.18 -1.13 -0.35
    2.49 -1.06 -1.18 -0.24
    2.38 -0.99 -1.25 -0.16
    2.31 -0.85 -1.29 -0.12
    2.14 -0.78 -1.34 -0.05
    1.95 -0.66 -1.32 0.00
    1.72 -0.59 -1.27 0.14
    1.58 -0.52 -1.27 0.16
    No injector or seal problem.
    Any more ideas for diagnostics before pulling the head? Or should I do the leak down test before?
    Camshaft and lifters also new, had a broken lifter a #4, that's solved. Glow plugs swapped also.
  2. Re: Cold misfire cyl #1
    Aug 2018
    EU
    Here's a video how it starts.
    https://www.youtube.com/watch?v=oGiKLZH-KfQ
    VCDS, this time, was quicker to show me values. Funny that it starts with:
    0.45 -0.24 -0.07 -0.21
    Then it gets all messed up.
  3. Re: Cold misfire cyl #1
    1841 Post(s)
    VCDS says +/-2.99 as a maximum but in my experience anything even approaching +/- 1 indicates an issue. You can see there that number 3 is fighting against number 1 to keep things smooth, keep in mind the 1 3 4 2 firing order. With the way it changes with temperature, the first thing I would do is change the head harness but over the last 13 odd years I have replaced a disproportionate number of ARL injectors compared to the ASZ which is puzzling as they are the same.
  4. Re: Cold misfire cyl #1
    Aug 2018
    EU
    Hi, thanks for the reply.
    Injector harness already swapped, same numbers.
    Is it time to pull the head off? Since cyl #1 has the biggest fuel compensation and also the lowest compression? Or could it be just a coincidence?
  5. Re: Cold misfire cyl #1
    1841 Post(s)
    You say it has had a new cam and lifters but what about the arms and were they reset to the new cam? Be warned about taking off a PD head, the term can of worms being opened doesn't do it justice, you could easily get yourself into a £3k parts bill without blinking.
  6. Re: Cold misfire cyl #1
    Aug 2018
    EU
    Yes, arms were reset.
    All the job is done by me, so no money for labour. Has I suspected, the rod on the cyl #1 has scoliosis. I'm looking at about 250€ tops on parts.
    All TTY Bolts, Headgasket, bearings, rings for all pistons, and somethings I might be forgetting.
    Pistons not in order:
  7. Re: Cold misfire cyl #1
    1841 Post(s)
    Ahh, Banana rod....
  1. Please Help Misfire when cold
    By jones_440 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 18-01-2016, 09:13 PM
  2. TDI Cold Misfire
    By Phil20658 in forum Golf MK4 - 1999 - 2004
    Last Post: 27-09-2011, 10:04 AM
  3. Question 16v engine misfire when cold
    By bob57 in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 13-01-2011, 06:45 PM
  4. Please Help A3 misfire on cold
    By noomiij in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 17-09-2010, 04:23 PM
  5. Question 2.0 tdi - misfire on cold start up
    By bltdsimm in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 20-10-2009, 02:49 AM
