Thread: Pulsating sound from exhaust
  1. Pulsating sound from exhaust
    Aug 2018
    Nottingham
    Hi all,
    This is my first Touareg and I've got a V6 Altitude on an 06 plate and i've had the Exhaust - Workshop warning light come on and noticed a "pulsating" sound from the back box, i'ts doing this when driving AND idling ? is this more than likely the back box itself ? I've replace numerous exhausts when they've failed at MOT (i.e being told which bit is faulty) but not needed to diagnose it myself ?
  2. Re: Pulsating sound from exhaust
    1840 Post(s)
    At that age there is no way it needs a new exhaust, modern VAG exhausts seem to last forever, but you need to get it code read to see why the engine warning light is on, it is possibly a failed injector which is common on these engines.
  3. Re: Pulsating sound from exhaust
    Aug 2018
    Nottingham
    Could a failed injector cause the pulsating sound from the rear then ?
    I've got a cheap ODB reader and used Dash Command and it's given me code P2112 Throttle Actuator Control System - Stuck Closed ? Could it be that the exhaust is fine (as you've said) but it's throttling incorrectly in which case that would account for the "pulsating sound" possibly ?
  4. Re: Pulsating sound from exhaust
    1840 Post(s)
    Difficult to tell without a proper code read and some time spent looking at measuring block info such as injector balances.
  5. Re: Pulsating sound from exhaust
    Aug 2018
    Nottingham
    Right, thanks
  6. Re: Pulsating sound from exhaust
    Aug 2018
    Nottingham
    Just to close this...........i opened the throttle body and found the plastic cogs worn.....i got a repair kit off ebay and fitted it and the sound is now gone....throttle response seems better again as well.
  1. New S3 Saloon Coming but that exhaust sound :-(
    By nawaid in forum 2.0T, TSI and TFSI - Engine
    Last Post: 07-09-2015, 09:14 PM
  2. Maxhaust Sound Booster for Active Sound Exhaust?
    By DazNicholl in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 02-06-2015, 03:52 PM
  3. exhaust sound question?
    By clive30v in forum Chat - Completely Off Topic
    Last Post: 19-07-2009, 04:34 PM
  4. 1.4 Can you get a sports exhaust to make a better sound from it?
    By dean-nez in forum Golf MK4 - 1999 - 2004
    Last Post: 29-07-2008, 06:19 PM
