Thread: Battery Replaced - Now more faults than Theresa May
  1. Battery Replaced - Now more faults than Theresa May
    Jun 2011
    Hudds
    Car: 2008 Audi A4 B8 Sline 2.0 Tdi 170
    So long story short, I went away for a week and came back to a flat battery. Jumped started it and all was fine but the next day it did it again.
    After a bit of diagnostics it looked like the battery was bad which i believe was the OEM battery so not bad going for 10 year old.
    Anyway old battery was a Varta with part no. 8K0 915 105 F so went onto the Varta website, put in that number and it came back with a Varta i1 Silver Dynamic 610 402 092
    So managed to source one and fitted it, car started up and I thought that was all done and dusted.
    Just come out to drive to the shops and nothing is working!! Car starts fine but is complaining about all sorts
    Parking brake malfunction
    headlights
    wipers don't work
    indicators don't work etc etc
    Ran VCDS and pretty much every component has a fault and some unreachable.
    Can someone explain please as to what I have done/not done correctly?
    Thanks in advance
  2. Re: Battery Replaced - Now more faults than Theresa May
    Oct 2012
    Estonia
    64 Post(s)
    Delete all faults, it is normal if you swap dead battery and not having other power source connected that time!
    A48K5 2008 Retrofits: FL Taillights, Bixenon, Color Cluster & FL S5 Cluster, ADS with button, MMI 3G & 3G+(With Street view) Other Stuff: Ecu tune, Front bumper valance "Rieger look", Sideskirts, VCDS mod, Interior leds, Basic sound to Audi SS + B/O sub/tweeters+activsub, Soundproofing,Tinted windows, Interior 6D carbon wrap, Painted calipers, 18" Wsp wheels Peeler style, FL gearknob, Efficiency prog via cluster & gateway flash...
  3. Re: Battery Replaced - Now more faults than Theresa May
    Jun 2011
    Hudds
    Sorry to question but would that prevent VCDS from reading the Address 09: Cent. Elect too?
  4. Re: Battery Replaced - Now more faults than Theresa May
    Oct 2012
    Estonia
    64 Post(s)
    No, you should have access to all modules regardless...now stupid "all fuses check" and hopefully it will solve your issue, but still delete all faults first which you can!
  5. Re: Battery Replaced - Now more faults than Theresa May
    Jun 2011
    Hudds
    Checked as many fuses that I know about
    Cleared all the faults and just as many came back mainly moaning about "Control Module for network (j519)"
    I cannot get to the Cent. Electrics on VCDS it just says cannot be reached
  6. Re: Battery Replaced - Now more faults than Theresa May
    Oct 2012
    Estonia
    64 Post(s)
    Very odd result if j519 really "burned out - dead" due battery swap!
  1. Battery replaced
    By Sfour in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-09-2014, 11:16 PM
  2. Replaced Battery - ESP Light stays on
    By z3rochilled in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 09-03-2013, 02:00 PM
  3. Won't start after battery replaced
    By leroy2583 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-09-2011, 06:19 PM
  4. HELP: Replaced battery now immobiliser keeps cutting in.
    By gazzoo in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 25-09-2009, 12:43 PM
  5. Please Help Programming key fob after battery replaced
    By dieselglider in forum Bora - 1998 - 2005
    Last Post: 08-06-2008, 06:20 PM
